My Evil Plan
Re: My Evil Plan
Postby m.colley » Wed Mar 30, 2016 5:57 pm
chiefairwrench wrote:Quick question what do you use to attach the ceiling panels? :NC
Hey Chief,
I used liquid nails and a 1/4 crown air stapler on mine. The narrow crown is easy to hide with a dab of caulk or putty. I'll cover the seams (on the long edge) with painted wooden lattice strips to give it a more finished look. My ceiling is painted and I'm waiting to finish up the final trim out. I'm waiting to do the trim out until I make sure I have all my electrical runs finished.
Martin
m.colley
Images: 83
Re: My Evil Plan
Postby lrrowe » Wed Mar 30, 2016 6:38 pm
I used pan head type screws going into the overhead beams. In my case I added 2x4 crossmembers secured to the aluminum crossmembers.
Bob
lrrowe
Images: 439
Re: My Evil Plan
Postby chiefairwrench » Sat Apr 02, 2016 6:21 am
I purchased WFCO ULTRA III Power Center Model WF-8735Pa for my trailer since I am using more shore power than battery after getting my lights and started my wiring I realize that the negative is not available. Does my light negative runs back to the battery or to the frame? I am pretty sure I am missing something here. Install booklet was no help :frightened:
chiefairwrench
Re: My Evil Plan
Postby Padilen » Sat Apr 02, 2016 6:50 am
Use a terminal block-ground block.
Padilen
Re: My Evil Plan
Postby chiefairwrench » Sat Apr 02, 2016 7:55 am
Great it just a terminal block I was missing That was a big help Thank you :applause:
chiefairwrench
Re: My Evil Plan
Postby flboy » Sat Apr 02, 2016 7:56 am
chiefairwrench wrote:I purchased WFCO ULTRA III Power Center Model WF-8735Pa for my trailer since I am using more shore power than battery after getting my lights and started my wiring I realize that the negative is not available. Does my light negative runs back to the battery or to the frame? I am pretty sure I am missing something here. Install booklet was no help :frightened:
If you ground your Battery to the chassis with a heavy gage wire (6 ga would suffice for lower current lights and fans), you can ground each individual circuit to the chassis. That is typically how you would do a 12VDC installation. It saves the run of each ground wire. If you have a bunch of items to ground in a close proximity, you could use a ground terminal that is grounded to the battery for convenience . Electrically, there is no difference.
For high current item such as an inverter, you want that as close to the battery as possible to eliminate line loss, and in that case, you'd wire directly to battery terminals with the same Gage wire.
The positive side needs a terminal block with fuses... but that is what the WF-8735PA does for you.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: My Evil Plan
Postby chiefairwrench » Sun Apr 03, 2016 4:53 pm
Thanks for all your help not much to show rough wired getting ready for my ceiling hopefully pics next week. I did work at a a beer fest wife won a competition and was able to serve her beer she made at the festival in a 1965 VW BUS took pics enjoy. Oh and KISS Tribute band It was so much fun. :beer:
chiefairwrench
Re: My Evil Plan
Postby chiefairwrench » Sat Apr 09, 2016 11:42 am
Dont know what happened but I am not motivated this weekend started finishing my rough wiring and Started to get my ceiling supplies and boom totally not motivated to work this weekend .. it is cold maybe thats it :x
chiefairwrench
Re: My Evil Plan
Postby McDave » Sat Apr 09, 2016 1:55 pm
Hey Chief,
Take a break, maybe go for a ride and take the ol' lady out to dinner. Come back next week and hit it hard. :thumbsup:
McDave
McDave
Images: 412
Re: My Evil Plan
Postby chiefairwrench » Sat Apr 09, 2016 5:01 pm
Watch the Science channel after both of us had four beers my lady and me went and did 2 ceiling panels 2 more to go :beer: Apparently our mind juices as well as our beer meter was low.
chiefairwrench
Re: My Evil Plan
Postby McDave » Sat Apr 09, 2016 6:18 pm
:beer: It's not just for breakfast anymore...
McDave
McDave
Images: 412
Re: My Evil Plan
Postby chiefairwrench » Tue Apr 12, 2016 12:31 pm
Starting to reorganize should have my list done by the end of the day.
chiefairwrench
Re: My Evil Plan
Postby chiefairwrench » Wed Apr 13, 2016 6:58 am
Here is the current to do list: 1) CEILING-Install lights,, Install AC controls, Run Negative wire,Install 2 more ceiling panels and Aft Installation, Install Trim. 2)Electrical- Install electrical box, Battery switch, install negative(ground)block, Install 120 outlets, Install Battery phone charge outlet. 3) Walls - Paint , Install Trim. 4) Counter-Install Cabinet Doors, Install sink,Plumb water and waste water container, Fabricate back splash. 5) Build bed 6)Install microwave shelf 7)Install Motorcycle Lock system. Have to ahve everything done by middle May :oops: Lets see if I can do it
chiefairwrench
Re: My Evil Plan
Postby Jrst67 » Thu Apr 14, 2016 5:37 pm
If you use ground washers and a very small dab of dielectric grease on the ground there is no need to run a separate ground wire as was mentioned earlier.
Sent from my SAMSUNG-SM-N910A using Tapatalk
Jrst67
Images: 7
Re: My Evil Plan
Postby chiefairwrench » Thu Apr 14, 2016 6:36 pm
Ok great I will be wiring until I am done this weekend. Currently traveling anxious to get home and get going :thumbsup:
chiefairwrench
