Hi MtnDon
Im just giving you some JAZZ... one needs air to transport the moisture. So my point was if the cavity was 98% filled with foam.... Ridged or sprayed.
THEREFORE....only a very small or limited amount of air can get in, assuming of course no grand canyon volume of air circulation through the cavity
so I would assume less air volume = less condensation. Just as if I would press foam against your RV glass - the area of solid contact with the glass would have less or no condensation.
While about 30% of heat loss is due to circulation inside the walls, electric outlets, ceiling lights, eves, windows etc....
I have left some sections accessible & am interested to see exactly what happens.
I have 6 = 120 mm fans where covers can be removed to provide mechanical air flow as needed.
I can also tell you for sure there is air between the exterior skin & alum siding as the sheets are only 4ft wide.
While your & Prem's method of spraying foam is surely more effective, I see some drawbacks for me due to my extensive exterior lights & wiring I don't want it to be incased inside the foam.
also if the was a problem with the wiring its harder to find & may increase the heat load to the device ?
Time this spring will tell if it is good enough ?
My feeling is many RV's rot from the inside out - more then from exterior leaks, if used in cold weather.Jerry
