lonerider wrote:Question....why have you put the "Galley/Shelf/Battery unit in the back? Seems you are adding alot of weight behind the axles. Won't that screw up the balance of the trailer?
pete42 wrote:Do you plan on adding a strap to hold down your battery or does the metal piece hold it down?
pete42 wrote:Do you think a 30 inch wide door would make a good bed once a matteres was added?
Curtis in Texas wrote:You're going to wish you'd tied that down some day.
Trust me!
Even if you only add a block with thumb screws to the wall above the battery to keep it in the hole.
One good pot hole and it will bounce. And a broken battery case in your trailer will make a heck of a mess if it doesn't start a fire first.
EvenMercedes have their batterys secured even if they are never taken off the pavement.
With your battery in the rear of the trailer will be like riding the back bench on a school bus.
Curtis in Texas wrote:Really enjoying your build!
Will your bed fold up?
Sure would be nice should you ever wish to take a scooter camping with you.
pete42 wrote:How about an electric motor for that thing?
