Our build plan
Re: Our build plan
Postby flboy » Sat Feb 12, 2022 11:08 pm
It may be imbalanced and may or may not make a significant difference to handling depending on how much or if you can compensate with payload. .
Mine is similar unless I have the motorcycle loaded on the one empty side. So with the bike, I am roughly balanced, but without, it is definitely not.
For what I wanted to be able to do with my CTC, I saw no other floorplan that would work for me.
I was concerned and wanted try to mitigate any potential issues. The issue would be sway due to the preloaded springs on one side.
Google SumoSprings and read about them..They are progressive and similar to if you had airbags and compensated on one side with more pressure to level load. My CTC tows fine loaded or unloaded.
I think the SumoSprings help.
Don (Flboy)
https://youtu.be/6_-8cVdWUIA
https://youtu.be/MUcMM86LA2g
flboy
Images: 378
Re: Our build plan
Postby nsfr1206 » Sun Feb 13, 2022 8:09 am
Thanks for the reply. I’ll check em out.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Sun Mar 06, 2022 4:52 pm
Haven’t been updating… I’ve got a lot done. Ac is in and working, the ply is up on ceiling in bath and main area, lights are wired in. I am basically ready to put up nickel gap in bathroom and some of the living area. I still need to make it, I have poplar ordered for that. I suppose one of my next projects should be the cabinets so I can butt my interior wood finishes up against them. We could just about use it as it is. I need to caulk the exterior and my Airhead toilet hasn’t shown up yet. Hope it’s here before end of month.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Sun Mar 06, 2022 4:54 pm
For the ac I bought a 120v mini split. The outside condenser is mounted on rubber mounts on extended tongue. The indoor unit is mounted above bed pointing to the rear of trailer. The lines are ran through the v nose area.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Tue Mar 08, 2022 3:41 pm
So I have a question. Even with circuit breaker open overnight this is what my state of charge is. Why isn’t it charging up?
nsfr1206
Re: Our build plan
Postby flboy » Tue Mar 08, 2022 5:12 pm
Assuming all is hooked up correctly, is your charger in LifeP04 mode (it appears to be)and putting out 14.4 to 14.6 volts to charge? If it is in Lead Acid mode.. it will only put out ~13.6 V which will only get you to about 90%. Also, any way to monitor cells internally on that battery? Could be a top balance issue internal to the battery where one cell is shutting it down. .
Don (Flboy)
flboy
Images: 378
Our build plan
Postby nsfr1206 » Tue Mar 08, 2022 5:15 pm
flboy wrote:Assuming all is hooked up correctly, is your charger in LifeP04 mode and putting out 14.4 to 14.6 volts to charge? If it is in Lead Acid mode.. it will only put out ~13.6 V which will only get you to about 90%. I don't know if that is automatic or a configuration setting for your charger.
Quote from the place I bought it-
Designed for 6-volt and 12-volt lead-acid automotive, marine, and deep-cycle batteries, including flooded, gel, AGM, and maintenance-free, plus lithium-ion batteries.
I have it in lithium-ion. Maybe this charger won’t work for my needs?
Edit- this was on there also- Lithium Mode is for LIFEpo4 batteries with BMS. Charge rate is 14.6v for use with batteries up to 230 ah.
nsfr1206
Re: Our build plan
Postby flboy » Tue Mar 08, 2022 5:17 pm
Measure the charger voltage with it unhooked from the battery. What does it read? BTW... assuming you mean breaker closed?
Don (Flboy)
flboy
Images: 378
Re: Our build plan
Postby nsfr1206 » Tue Mar 08, 2022 5:35 pm
It shuts off when load is unhooked. But my guess is it’s thinking it’s fully charged at 13.6v or so. So either bms on battery is messed up or charger.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Tue Mar 08, 2022 5:37 pm
flboy wrote:Measure the charger voltage with it unhooked from the battery. What does it read? BTW... assuming you mean breaker closed?
I should have taken another pic. The breaker I’m referring to is between battery and the load center.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Wed Mar 09, 2022 5:18 pm
Here’s some more pics. This is state of charge today. Circuit breaker had been off since yesterday sometime…Image
nsfr1206
Re: Our build plan
Postby nsfr1206 » Wed Mar 09, 2022 5:19 pm
Obviously I had closed breaker right before pic as you can see how many amps I’m putting out.
nsfr1206
Re: Our build plan
Postby nsfr1206 » Fri Mar 11, 2022 10:20 pm
I’m assuming the charger is somewhat wonky…. I ordered a new charger this evening. We shall see…
nsfr1206
Re: Our build plan
Postby nsfr1206 » Sun Mar 13, 2022 6:03 pm
I tell ya. This charger has me flummoxed. The meter shows today having battery at 14.2v but only charged to 72ah. That’s with basically no draw on battery other than the Renogy meter since yesterday evening. Something has got to be wrong. The question is what.
nsfr1206
Our build plan
Postby nsfr1206 » Tue Mar 15, 2022 4:59 pm
I bought a Victron smart charger. It doesn’t seem to want to charge the battery either. I’m going to try to get battery replaced.
nsfr1206
