Very slick!
Since the rear isn't being used for an outside galley, the use of the stock doors for utility access is a great feature.
I assume that the vent in the right-hand rear door is an air intake for the air conditioner, which exhausts directly out the left-hand door (or
vice versa). A very simple but effective design.
I agree that the SRM-24 type battery is not ideal for the application because it is a compromise deep cycle/ starting design, while the U2200 are more likely to be proper deep-cycle units (although they are strangely listed as "Deep Cycle/Cranking" as well) and usually better priced per unit of capacity; I notice that when listed under
Industrial, that same U2200 is described as strictly "deep cycle". The voltage isn't the important feature.
Is that water heater actually mounted in the left door?
My only concern (similar to Ron's) is that most of the heavy items are at the very back (water heater, batteries, air conditioner), and the propane tanks are very far forward, so it seems like the mass is concentrated at the ends. This is opposite of the situation desired for best stability (mass concentrated in the middle), which may be why the sway control is apparently needed for a modestly sized trailer. I assume that the tongue weight is okay because the axle is suitably far back. What's the current tow vehicle? (Or was that listed and I missed it?)
![Question Mark :QM](./images/smilies/mercury3b.gif)
