So I built this false wall for a cargo trailer I bought.
I searched ebay for a trailer and finally found one for a decent price because the location was mislisted and no one but me bid on it.
I picked this up for $900 it only had 50 miles on it and still had the little knobbies on the tires.
The first thing I did was install a removeable wheel chock and tie downs inside. I then installed a roof vent and a toolbox on the front.
Then I built a false wall for the back of it. The wall is removeable and will either stay in place when traveling or I strap it to a wall.(when Harley is inside.)
I offset the wall so the back door can still close when it is in place.
The start.
Adding aluminum angle to get offset.
Adding aluminum
I installed seals around the cargo doors frame for the false wall to seal against and then installed a header above it so I could put in t-bolts to hold it in place,The bottom is held with 2 eye bolts that hold it snug.
The top is held with 3 knobs with bolts that attatch to the t-bolts.
I also installed an electric panel to control outside and interior lights.
While building the wall I built a air conditioner door. I used angle aluminum to make mounts for the AC. I use simple turn catches to hold it in place. The door also serves as a table when the AC it in it.
I then built a holding tank out of PVC and added a on demand pump. It hold 8 gallons and I can get 3 showers out of it.
The inside is nothing special as I only throw a twin mattress in there to sleep and keep my camping supplies in a foot locker. I also wanted to keep it a cargo for hauling stuff. But it is comfortable and good to be clean and in the AC after a day of fishing, riding or hunting.
I put on a kayak rack and when fishing alot I can keep all of my rods and tackle in it ready to go.
