Hot Water Heater installed
Postby southpennrailroad » Sat May 08, 2010 5:43 am
I partially installed my on demand hot water heater yesterday and it seems to work great. I bought a 12 volt pump $30.00 HF, to lift the water to the heater from a blue seven gallon water tank. I now know that the tank has to be just above the pump for the water to get pumped out. Instead of a hose I bought adapters to clear hoses to provide for supply lines. Mounted the heater to just above the sink in the back right side door. pump is planned for the bottom of the door and on the back outside of the door is where I plan on putting the water storage tank. Will need to get longer wire to supply the battery and a shut off switch to control the power between rinse wash and rinse. I am sorry this should have been in cargo trailer section.
Long time researching the abandoned South Pennsylvania Railroad along the Pennsylvania Turnpike. God will guide me. As he has done so in the past. southpennrailroad.com
southpennrailroad
Postby Rickxr2 » Sat May 08, 2010 6:37 am
What type on demand heater did you use? Is it the kind you put at the sink for a single cup of hot water, or a big unit for dishes and showers? Just curious.
Image Image Image
Rickxr2
Images: 125
Postby southpennrailroad » Sat May 08, 2010 9:41 am
Rickxr2 wrote:What type on demand heater did you use? Is it the kind you put at the sink for a single cup of hot water, or a big unit for dishes and showers? Just curious.
Eccotemp on demand hot water heater. I do a lot of off grid camping and take lots of walks in the woods and wanted something to clean off with after thw hot walks. I am i my trailer now but only in shorts and some what cold in the blankets to get up and show how it looks. Love to show photos but just to lazy for now.
southpennrailroad
Postby madjack » Sat May 08, 2010 12:48 pm
...the age old question applies...why do you need to heat hot water(unless making steam)??? :D :lol: ;) ...I'll move this to the section you wish........
Postby Prem » Sun May 09, 2010 12:09 am
I have a hot water cooler in my tow vehicle. Use it constantly. Works GREAT.
:roll: ;) :lol: :rofl2:
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby SirJoey » Sun May 09, 2010 7:20 am
madjack wrote:...why do you need to heat hot water...
I ask myself that very same question every time I see or hear the almost universally accepted term "hot water heater"... :?
When all is said & done...
a lot more gets SAID than DONE!
SirJoey
