Anyways Im new here obviously by the first post heehee but I have been viewing your guys builds for a while now and can’t believe the things you have done with the little space you have to work with! So I commend you all for that! I thought I would be flying solo at the time when I had my build idea thinking I could be a original I tell you I was wrong and I couldn’t happier for it!
So just a little heads up im going for the Weekend Warrior / Cheapest I can possible be! (Because I have priced some cab over’s and small trailers as well as tent trailers and nothing is close for what you get! As well I would like to keep this as a cargo trailer as much as possible for toys!
So I’ll try to give a total tally of cost at the end of my adventure as a budget build if all possible! Hopefully it will help someone as you all have helped me with inspiration as well as knowledge!
Please also feel free to pick me apart as to I have minimal knowledge! Always nice to get criticism or suggestions!
Here I am so far! I have a pretty busy life but ill do my best to update until the end! *** Also sorry for some of the crappy cell phone pictures
The trailer!
Trailer inside! – Had to patch a hole on the back right side..
Front inside Gutted and ready for insulation!
Out the back Gutted! – Please don’t mind the garage! It’s a war zone in there..
Small cut out I made for my power! (measure twice cut once!!!)
Trailer inside put back together and floor bed liner (though wasted $50 on this.. floor had oil on it and most is peeling up as to I guess I didn’t prep enough), but I have a back up flooring in the works.
Small door problem.. someone wanted something more than I did.
Door fixed!
New handle!
New Hinges I made.. not the best but they are strong and work. Though could use a few more screws.
So my start to the inside!
Made a Murphy’s style bed! - Though tested it and needs a bit more cross bracing.
The start of my counter and cabinet’s im making’! (Front wall)
*** Sorry thought I had a shot of the electrical.. (it’s nothing special mostly a full 12v system with a battery retainer)
Another shot of the Cabinets / Counter (left wall)
This Left side is going to have a open compartment for bedding storage.
New full view of the Trailers inside!
This is where I am so far im looking to get it done by the end of the month or at least camp able as to im planning on going to the ocean on the 2nd week in June and then become the weekend warrior I want to be! Thank you for looking! Hope to have some updates over the weekend!
Goals to finish the Cabinets as well as add a upper cabinet!
Im looking to add a collapsible table on the opposite side of the Murphy’s bed.
Also looking to insulate / cover the roof and add lighting as well as add a exhaust fan in the vent.
Then redo the flooring.. / Paint to Suit!
