I am installing a water heater and shower box plumbing. Water heater has 1/2" NPT threaded fittings as does the back of the shower box. I am using brass 1/2" NPT to 1/2" female barb fitting for the water lines off the water heater and into the shower box.
My question is: Which would you choose to best seal the 1/2" NPT connections; plumbers putty, Teflon tape, or something else? My plumbing going into and coming off the water heater is near my electrical (due to space confinements in the CT). I will be installing splash guards to direct a water leak, should one occur, away from the electrical boxes but I want to make the tightest/leak-proof connections I can (SUBSAFE would be nice but I can't afford that... submariners will know what I am referring to).
Thank you for your help,
Don
