from here:
http://www.thriftyfun.com/tf736565.tip.html
Charcoal works very well at absorbing odors, but be sure to use pieces without lighter fluid. If necessary you can seal the piece with shellac.
______
I had a similar problem with a wood floor in a garage. I soaked the area with liberal amounts of 91% isopropyl alcohol, scrubbed it with a stiff brush, wiped up the excess, and then put a fan on it to help evaporate the remains...worked like a charm! Went from overwhelming to no smell with one treatment.
_______
You can stuff the drawers with crumpled up newspapers. They usually take odors out of things easily. Wait a few days & then remove newspaper. If it's not gone yet, do it again. It should work!
