How to mount Solar Panel to roof of CT?
Hello! I am new to this forum, and found it looking for info on my own conversion design. I just bought a used Haulmark 6x10. It already has windows and an insulated roof with a thin whiteboard liner, so I can't see any of the roof trussing. I have figured out by the screws inside that the ribs are on 24" center which is perfect for my panel.
My question is - the roof is seamless, and seems to 'float' un attached to the trusses. Is it going to be OK for me to just punch a bolt hole all the way through the truss and roof from below (a small one with washers) to bolt it down with, and seal it well with silicone?
Perhaps I should add that I just noticed after some pretty bad weather that the center vent leaks a few drops. It is pretty UV damaged, and I want to replace it with a self-powered unit, so at some point soon I am going to need to peel off the thick weatherproofing goop, and replace the whole shebang.
Thanks for your thoughts!
