My biggest concern with converting this to be a duel use travel trailer/cargo trailer is the fear that it would be relatively easy for someone to trap us inside the trailer. Not to mention there is not a great way to close and secure the door from the inside but that is the easier of the two issues to address.
The immediate fix I have come up with is to install an Escape Hatch roof vent of some type (I need to add a roof vent anyways) for example something like this:
http://www.rvpartscenter.com/ProductDetail.asp?PID=35529&SID=9&DID=54&CID=260
or
http://www.rvtruckparts.com/ProductDetail.asp?PID=35531&SID=9&DID=54&CID=260
I need to actually measure my roof trusses to figure out how big I can go.
The second option I have considered is to remove the cargo style lock on the side door and either add a RV type handle or perhaps look for an entire replacement door. The problem here is I have a fealing that my relatively inexpensive trailer (about $2500 new) might not really be worth investing that kind of money as some day I might well want to move up to a heavier tandem axle trailer.
I am sure many here have struggled with this. Is there other options I have not thought of or if these are my two (or is that three) options what works best without blowing the budget.
If this is going to cost too much, I might be better off selling my trailer used and look at the bigger trailer now and order it custom built to get better doors and a window.
