I am making slow but steady progress with my CTC. Here is what I have so far. The small bunk on the left and the bench on right are easily removable. I use a dowel to secure it. The front legs arepermanently attached to the bench and bunk, the back legs to the wall. Once removed, I have a large cargo area. The front bed is permanent. The little wire shelf unit is for the small galley area I will have, most of the cooking to be done outside. Using the wire rack, I can easily fix it to wall and hang some things on it. Next I want to get some windows in.
