Has anyone had problems with this method? Does it seem to work well? Is it going to stand up for years, or should I bight the bullet and go linoleum? Any opinions would be greatly appreciated.
Thanks for looking
tk wrote:You say "bite the bullet" implying that linoleum would be more expensive than epoxy paint. I'm not so sure that is accurate. If you haven't actually checked that out, you should. Anything that has epoxy in the name is generally expensive. Vinyl flooring remnants can be had quite cheaply from flooring retailers as well as wholesalers.
Best,
vtx1029 wrote:Just did our trailer in the lick and stick 1' squares. Under a $100 bucks for our 8.5 x 23' trailer![]()
We had a single piece of linoleum in our other trailer it did hold up pretty good but it was not glued down only attached to the floor around the edges with trim. It did hold up ok but some tires have a tendency to leave black marks on the floor. We went with the 12" squares on this one so we can replace a tile if it gets damaged
Users browsing this forum: Google [Bot] and 12 guests
