6X14 V-Nose Conversion Start to Finish 6 weeks
Postby UtilConversion » Mon Aug 08, 2011 11:43 am
The enclosed webpage shows the start to finish of my Wells cargo V-Nose camper conversion. I used marine vinyl to cover all panels. I have both Shore power and internal marine battery 12 vdc Systems. Took it to lake Amador for a test trip a couple of weeks ago. Only fault was a minor water leak when connected to a water supply. I made all of the cabinets and frames using a Balsa cored 3/4" ply that is super light yet quite strong. !/4" ply used on wall skins over 1 1/2" insulation foam panels. Latex expandable foam to fill voids. Flooring is a vinyl floating plank from home depot and works really well.
Biggest issues was the lack of straight walls and even stud spacings making everything requiring a custom fit. Cost to convert about $4500 which includes all systems fittings etc.
Traveling with this thing is so easy behind my Dodge Ram 4.7L two wheel drive truck. Had to climb a lot of very steep long grades between Reno NV and the lake in California. Even with on board water tank filled 50% the camper felt very light and maneuverable. I figure about 600 LB added with the conversion.
For sleeping I have a coleman double queen air bed that is very comfy. This I had to buy after my first campout as the original went flat the first night. I have a ramp so can also carry my full sized ATV in the back with the mattress folded.
Check it out with the following link. For anyone interested the home segments button will take you to another link showing my Fiat Spider restoration and other goodies.
http://gallery.me.com/jamesaellis1#100237
UtilConversion
Postby David_L6 » Mon Aug 08, 2011 12:17 pm
Very nice. :thumbsup:
David_L6
Images: 16
Postby wtcreaux » Mon Aug 08, 2011 2:04 pm
NICELY done and documented. :applause:
I'll be using some for mine. Where did you find the marine vinyl walls??
wtcreaux
Images: 211
Postby Wolfscout » Mon Aug 08, 2011 4:09 pm
nice.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby UtilConversion » Mon Aug 08, 2011 4:13 pm
wtcreaux wrote:NICELY done and documented. :applause:
I made them. I used 1/4" ply then contact cement spray. The adhered the vinyl to the panel. One tip is always try and roll your edge over. If not the vinyl can begin to unwrap in excessive heat due to remaining pliable. A couple of spots did this due to high ambient temperature in the desert.
UtilConversion
Postby pmspirito » Mon Aug 08, 2011 9:02 pm
Awesome walls. Can you give us any more info on how you made them. What is "marine vinyl" is this like that Naugahide material use on seats etc in street rods?
see my cargo trailer build at viewtopic.php?t=45197
Peter Spirito
www.peterspirito.com
pmspirito
Images: 112
Postby 8ball_99 » Tue Aug 09, 2011 12:39 am
Looks great!
8ball_99
