I almost laughed as I found this site to find that it's already been done a hundred times over.
Remember the old story of the ugly duckling and he finds out that he's actually a swan, and there are many swans! I mean just look at all the swans on this site.
Anyway, I have read some of the stuff posted on here and marveled that a lot of the things I have encountered on this adventure have been dealt with in exactly the same manner as I've done, (or done better than I).
Thought I'd share a few nuggets from my own build, and update as I go. So here goes:
The rear ramp door open and the bed all stowed away.
The ATV loaded and lashed down. Not much room to spare! The left rear and right front tires are held down to E-track on the floor by tire web. Good enough that race cars are transported with these things.
Besides, no room for tie-downs. I can get at the right front via the RV side door and the rear via the ramp door.
The bigger side of the bed. The table slides into it's holders, two 6" 1 1/2 angle iron pieces inset into the wood rails hold the four foot long table up by its middle. To get it out I just unhook the bungee, swing out the table legs, slide the whole table two feet to the left and it's down and ready to use in seconds.
The first 8" of the bed is solidly mounted to the left wall and the rest swings up on a piano hinge. That gives me a place to store the two 4" thick 35 x 75 foam mattress pieces, side by side.
The other side becomes a bench. Swing the built in 2x2 legs out and unhook the bench and let it down off the wall. There's a bridge piece needed for the bed, that stays folded on its own piano hinge, for bench service.
For making the bed, unhook the bigger side, unfold its legs and lower it. The bridge piece is ready to drop into place. See the step where the bridge fits into the big side.
And voila: Wall to wall King size bed! (almost King size) That's a double wide sleeping bag rolled up against that window behind the netting.
Have a few more things done too, if people are interested.
