Roof and walls done ready for wiring
Posted:
Fri Sep 23, 2011 9:29 pm
by slipperyd12
Posted:
Sat Sep 24, 2011 7:34 am
by GPW
Slip , sure looks Nice inside !!!
How much wiring do you need to do ???
Wiring
Posted:
Sat Sep 24, 2011 8:52 am
by slipperyd12
I have pretty much all of thw wiring to do. I made the top corner enclosed to hide all the wiring.
Four 110V runs, A/C, lights, tv and outside plug. Then several 12V runs ,lights
fans, phone charger outlet. The only problem I have is my battery has to be in the cabinet inside. I guess I will get a box and vent it to the outside. My only delima seem to be can I vent it through the floor or does the vent need to be higher than the battery.
Re: Wiring
Posted:
Sat Sep 24, 2011 10:09 am
by David_L6
slipperyd12 wrote: The only problem I have is my battery has to be in the cabinet inside. I guess I will get a box and vent it to the outside. My only delima seem to be can I vent it through the floor or does the vent need to be higher than the battery.
Not positive, but I don't think that AGM batteries have to be vented. ???
If that is true, just buy an AGM battery.
Posted:
Sat Sep 24, 2011 2:17 pm
by CaptD
I read somewhere that batteries being charged produce hydrogen gas which rises. Propane gas settles/goes down. Capt D.
Posted:
Wed Oct 05, 2011 8:46 pm
by pmspirito
I am building "The TrailerShowroom 7x14" I am using two 35ah wheelchair batteries. They are completely sealed and can be installed on their sides or even upside down.
no venting is required. I have plug-in connectors on the batteries and remove one to power my trolling motor when I go fishing. then I pop it back in and recharge it.
