BC_Explorer wrote:One of the main issues with a CT is that they are wide, tall, long and they flex easily which could lead to popped rivet/screws and the sides of the trailer exterior can show some distotion patterns.
BC_Explorer wrote: You should at least inquire who the manufacturer is and ask for a spec sheet then do some dilligent research on these trailers before you decide to purchase.
BC_Explorer wrote:When planning for my CT to convert (which will be ordered soon) I had some of the same thoughts/questions as you.
BC_Explorer wrote:Yes I am in BC, the Vancouver area to be a bit more precise. I lived in many areas of the province and also have made several trips to Alberta over the years.
My view in summary, (and I sure there are many differing.)
The size of the 7x12 as compared to the 6x10 sitting side by side is considerable and there is also a weight difference. The 6x10' I will be ordering is only 1100 lbs dryweight wheras a 7x12 is 1510. This is not much, however for my needs, I would like to keep total weight down to about 2000 lbs.
The reason for the trailer brakes I mentioned, there is a highway route that I travel often.
This route is up/down over one of the steepest climbs in Canada for a paved highway (3400 feet in 7 miles.) The road has numerous switchbacks where the recommended posted speed is 10 miles per hour.
A house I once lived in had a 22x22 inch shower stall which was the size of an old phone booth. It was small but did the job so I think that 30x30" would probably work.
Stainless wrote:Hmm. I've made the thing work (in Sketchup) with the planned 30x30, but maybe I can go a little smaller and use the space elsewhere. I'll snoop out some shower pans and see how much smaller is reasonable. I wouldn't mind being able to, you know, raise my arms in the shower.
Thanks again. Very helpful.
S
Kharn wrote:For cargo trailers with a wedge front, is the wedge included in the length measurement, or is it only the length of the straight walls?
