How much power do you really need
Still waiting for my 6x12 haulmark to be built, and in the meantime reading everything I could find about rv electric. Not sure If I want to go all out with my power or simple and cheap. I know that most people in teardrops opt for regular old 15 amp service..What do the majority of cargoists go for ,15 amps or 30amps?? I know it will be fun to rig up a powerhouse of a camper but also expensive..I wonder if I will ever need all that power or if 15 amp service will suffice.. Not too sure what my power consumption will be..I guess a few trips would help me figure that out a little better. I think I need a little insight so I could figure this out. Should I stay simple or should I get all the bells and whistles??
Simple
15 amp service
Battery tender 6 amp charger
Gravity fed water system
02 cool walmart fan
surge protector outlet strips
Battery operated boom box
Powerhouse
30 amp service
converter with smart charge
water pump
fantastic fan
wall outlets
car stereo with speakers
I was thinking if I go the simple route I could just run 2 regular extension chords from the campground to the cargo-one of them plugged into the 15 amp service and one plugged into the 30 amp service (with adapter of course). This would give me more capacity.
Again, not sure what I will need to power...some must have items are.
5000 btu air in the summer
small heater in the winter
laptop/phone charging
Some kind of battery charger
Not sure how I feel about the small dorm fridge..I know for certain that I will not need a microwave, coffeemaker or television..
I know that the smart thing to do is just run a regular extension chord through a $5 dollar cable hatch and connect that to a surge protector and see if that works before I put in 30 amp..On the other hand that would delay progress on the cargo as the electric should probably get done before I insulate, cover the walls and ceiling, and start furnishing.
Please help! 30 amp or 15 amp for a small 6x12 cargo conversion????
Simple
15 amp service
02 cool walmart fan
Powerhouse
30 amp service
water pump
fantastic fan
wall outlets
