Box truck conversion...ideas for now
This might have gone into 'Non-Trad Designs' too. Oh well...here I go!
My goal is to have a standie on a pickup frame. Remove the box and build a flatbed then do a build on top of the flatbed. that way I would have two vehicles in one.
As I've worked my way through the mental design stage I realized that a smaller cube truck would work. They can be found in good shape with decent chassis.
This is what I'm looking at:
http://www.cardomain.com/ride/3802017/1 ... lux/page-3
Uhaul used them for years and they still have life in them.
Now...how to make the cube a tray top? This might prove to be a dead-end in my design. But...let me run it out.
The units generally have a solid 2" receiver hitch in the back. What if there were receivers mounted on the sides towards the front of the deck? Adding flat plates and bolting through the floor would make a solid lift point.
Now...the lift off.
Using square Bulldog jacks welded to tubing that would slip and pin into the three receivers.
Look at these:
http://www.bulldogproducts.net/content/ ... 540&part=0
When I want to slip the box off and have the flatbed I would attach the three jacks, unbolt the frame plates, jack up the cube and drive off. Slide on the flatbed, bolt it down and carry on.
Now...time for feedback?!
Now...the lift off.
Look at these:
