vreihen wrote:Can't the solar panels be used as a secondary roof?????
Blotto Bros wrote:While camping I watched a guy pull in with what looked like a contractors trailer and convert it on site.
He had a ladder rack on the roof that bolted to the top support rail on the sides of the trailer. He had installed snaps along the sides and just snapped a canvas over the top of the whole ladder rack to create an instant "SAFARI ROOF". He also stated that it reduced interior temps by 10 degrees or more.
You could use this idea AND simply make your canvas the same length as your trailer but twice as wide and have an instant awning as well.
8ball_99 wrote:I'm really not sure it would be worth the trouble. Also IMHO you would be MUCH better off just getting an extra tall ceiling in the trailer and adding the air gap there. That way the roof stays water proof. Or you could just add more insulation there then normal. You also don't want a 100% flat roof like your talking about cause it would hold water. Even the flat room trailers have a slight crown in the center for water run off. I have 4 different layers of insulation in my roof. I also have painted the roof flat white with paint made for metal roofs. Inside of my trailer in direct sun is no hotter then outside air temp. Atleast not enough to notice.. Of course that is with two roof vents open and one of them has a fantastic fan. Doesn't matter how you insulate it if you don't have any ventilation it will heat up sooner or later inside..
Optimistic Paranoid wrote:
Thanks for taking the trouble to respond. You're comments are interesting.
I'm thinking that the new roof would take the brunt of the water and keep the original roof fairly dry. As for run off, with a scissors jack at each of the four corners, I should be able to cant it just a hair and control which way the water runs off, at least while it is parked.
Regards
John
8ball_99 wrote:My line of thinking was your planning on screwing or bolting wood 2x and painted plywood on top of a metal roof. So even if the plywood top blocks most of the weather your still adding many holes to your nice hole less metal roof. Also you don't want have to control water run off by setting the trailer up off level. The water should drain off the roof with the trailer level. I just don't think the extra holes and wind drag is worth a little extra insulation. Not when you can do about the same thing with insulation inside..
BC Cargo wrote:To support it off the roof I used big suction cups like on the very old style roof racks. However I drilled through the cup completely and bolted it with a fender washer on the underside of the Jeep roof. This sealed good to the curve of the roof.
I think it would be a great idea to mount the solar to but is only required to go under the solar by the amount needed to mount it. So your roof is either covered by solar or ply but not both. This would also allow for more hot air to escape in the cracks made by the solar mounting hardware.
Optimistic Paranoid wrote:The thing is, I'm not contemplating doing this as a stand-alone project, but as part of adding solar power for boondocking. 3 solar panels will require putting a dozen holes in my metal roof, plus the junction box for the wiring ANYWAY.
An alternative approach would be to have the trailer built with about four ladder racks, spaced about 4 feet apart, and mount the solar panels on THEM.
The problem is, I'm not sure how well the factory attaches those things. Also, they look like they are designed to principally support weight pushing down. If there are large panels on them, how well will they resist any UPLIFT caused by the wind geting between the roof and the panels?
Anyway, still doing a lot of thinking, and appreciate your comments.
Regards
John
