Double Roofed CT?
As I continue to plan the ultimate cargo trailer conversion for when I retire in a year or two, a question has arisen in my mind concerning the roof.
I am looking hard at the possibility of mounting solar panels on the roof. The problem is, then you can no longer park under cool shade trees, but must sit out, exposed, under the hot sun.
A little while ago, I ran into a reference to the fact that, in the old, pre-airconditioning days, Land Rover used to offer an optional Tropical Roof. This appears to have been white canvas, stretched on a frame and mounted above the regular roof so as to create an air space of an inch or two. It was said that this option would keep a Land Rover 10 to 15 degrees cooler under the hot, tropical sun.
This has led me to consider putting two-by spacers across the CT roof, over every steel rib, and putting a light, 1/8 to 1/4 inch plywood roof over it. There would then be a 2" air space between the new roof and the original one. The solar panels would of course mount above the plywood roof, which I think I would paint with boat paint, or maybe some of that rubberized roof paint.
The upside is that it SHOULD keep the trailer cooler when parked out in the sun, and an added advantage is that the trailer should be quieter - and easier to sleep in - during rain storms.
The downside is that there will be added expense, and also it will add some weight to the project.
I was wondering if anybody here has tried this? Or any other comments on it's feasability? Or lack of same? Also, I guess this would require a trailer with a flat roof, as opposed to one with the rounded roofs. Any comments about the innate desirabilty of one style over the other, if any?
Thanks
Regards
Joh
Thanks
Regards
Joh
