Ramp Door Spring Mechanism Ceiling Cover UP
Postby k1hog » Mon Feb 06, 2012 9:48 am
How did You'all cover the ceiling above the ramp door spring mechanisun. Pictures would be great.
Thanks
Johnnie
k1hog
Images: 33
Postby capt4903 » Mon Feb 06, 2012 10:38 pm
I used aluminum diamond plate.....I believe it is roughly 3/32"....I figured dimensions and had local metal fab shop bend it up.....cuts real easy with fine tooth sabre saw blade....even done a little trimming with tin snips.....photos are in my album.....used self tapping panhead tek screws to anchor into metal frame work.....made the transition between the walls and ceiling with the same type diamond plate.....
capt4903
Images: 6
Postby 8ball_99 » Mon Feb 06, 2012 11:28 pm
I had the factory cover it with a piece of white aluminum like whats on the exterior of the trailer.. Think they charged 35 bucks to do it..
8ball_99
