Mounting an ARB fridge?
Postby darkinbog » Tue Feb 28, 2012 1:02 am
I"m looking for ideas on mounting an ARB fridge. I thought about strapping it too the top 0f a cabinet or maybe build a drawer with slides. Thoughts? I ordered the straps from ARB to use as a tie down. :)
darkinbog
Images: 10
Re: Mounting an ARB fridge?
Postby OverTheTopCargoTrailer » Thu Mar 22, 2012 11:08 am
Dude
Its got like 4 bolts that go into the feet ....... did you read the manuel ?
you just need to buy longer bolts when the surface is thicker, don't over tighten or your screwed
or you can buy their expensive as hell slide system
I have a 63 quart cooler, it works great but does not cool to the advertised temperatures....
mine is set at 26 deg F and what I put in frozen stays frozen, what I put in unfrozen stays unfrozen.
http://overthetopcargotrailer.blogspot.com/
:shock: :shock: :D
Postby elmo_4_vt » Thu Mar 22, 2012 5:42 pm
I'm setting mine (50 quart) on top of a cabinet near the door so I can reach stuff without getting in... Though I'm just mounting my by use of the ARB straps that I bought because I want to be able to take mine out quickly and put it next to my stove/sink/kitchen or in the back of my truck. I plugged mine into the wall so far, and it went right down to 30 with no issues. Still have to test it a little more on DC and to lower temperatures, but I'm super excited about not having to use ice next when we go camping next time. :thumbsup:
Don
Truck: '96 Ford Bronco, Modified for off-road stuff
Trailer in progress: Not a tear drop exactly, sort of a mut of a couple different designs.
elmo_4_vt
Postby bdosborn » Thu Mar 22, 2012 7:17 pm
I made a mount for our Waeco:
Here's a link to the full thread:
Cooler Tie Downs
Images: 806
