How to install window unit?
Now that I've finally started the build the only obstacle I've run into is trying to figure out how to install the AC. It's going in a 6x10 Interstate Cargo.
I bought a used 5,000 BTU GE window unit. It is only 18in wide x 14 tall.
I looked in a new Jayco that had one permanently mounted in an upper cabinet with a vent on the outside. I wonder to prevent leaks going that route?
I have come across a post on here before about using a cargo door with a slide.
Any ideas??
I cannot seem to find a small enough cargo door with a lock. I'd like one no wider than 21in If I go that route.
As soon I I get started with the actual building I'm posting pictures of my progress
Thanks
Any ideas??
Thanks
