I am converting a 8.5 x 24' trailer and was looking at one of the catalytic heaters. I see they make heaters that go from 1600-8000 BTU's. How many BTU's do you think I would need to heat a trailer this size?
Thanks for the help guys
Chris
Sevo wrote:Thanks guys for the replies.
After some research and after looking at 8_balls conversion I don't think the catalytic heater will be enough. I think I will go with the furnace. I feel this will be our best option to heat the entire trailer.
If you guys know of a good one on sale please let me know
thanks for the help
Chris
8ball_99 wrote:Np, And don't get me wrong a 8000btu would probably work. Just would take a long time. If you can stomach a RV furnace its really the way to go.. I got Very lucky on mine.. On ebay I bought a suburban 19k ducted furnace brand new in the box for around 320ish.. At the time it was atleast 150 cheaper then I had seen anywhere else.. Might be worth keeping an eye on there. Just really look hard at anything used. Some times you get lucky and people just upgrade to larger units quickly.. I'd avoid older units or anything missing parts.. You better off just buying new cause you can easily spend a couple hundred bucks getting a bad one working..
thanks for the help
Chris
