Page 1 of 1
I found me a 7x10!
PostPosted: Sat Apr 28, 2012 9:02 am
by Partsman
After work yesterday I went to look at an "Old 12 foot motorcycle trailer".
This is what followed me home!
7x10 Cargo Star with full interior, cabinets and floor already in it.
This sucker is built too. Huge channel frame, 2 5/16 ball and brakes.
I think I can put off the build thread until winter with this one.
Window, A/C, and beds is all I "need" for now.
Re: I found me a 7x10!
PostPosted: Sat Apr 28, 2012 9:26 am
by b.bodemer
What a great find. With only a few more things you are ready to camp!
Barb
PostPosted: Sat Apr 28, 2012 4:17 pm
by pappaw
sweet find. :thumbsup:
all you need is a blowup (bed not doll) :o
Cheers: Jeff :beer:
PostPosted: Sat Apr 28, 2012 7:51 pm
by SteveB
That has to be to score of the year! Nice find. Steve
PostPosted: Sat Apr 28, 2012 8:58 pm
by Partsman
Thanks all. I was realty excited when I saw the inside.
BTW It is US Cargo. Not sure where I came up with cargo star.
PostPosted: Sat Apr 28, 2012 9:39 pm
by Gadget Man
I like that trailer.
The inside is halfway finished already. Is there any insulation in it?
Gadget Man
PostPosted: Sat Apr 28, 2012 9:53 pm
by Partsman
I am not sure about insulation. I spent all afternoon on the floor.
Spent the afternoon removing chocks and diamond plate.
Took me a while to find the right screw bit.
PostPosted: Mon Apr 30, 2012 8:06 am
by Partsman
Picked up some white Rustolium for this. If it ever stops raining here that is.
I am having trouble with the interior lights. They worked when it was hooked to the previous owners truck.
Not so with my truck. Then I tried using some jumper wires and my boat battery. Still no luck.
PostPosted: Mon May 21, 2012 3:35 pm
by Partsman
New pics.
Stripped down the driver side wall.
The window is in! Already cooler inside!
Insulation on that side.
PostPosted: Mon May 21, 2012 3:38 pm
by Partsman
I also scored a queen size mattress. It is thicker than I wanted but free and it was in the spare bedroom so not worn out and smelly.
PostPosted: Mon May 21, 2012 4:15 pm
by bigbendhiker
Awesome find. :thumbsup: Looks like a really stout trailer.
While you have the interior walls off, you can plan for any additional wiring that you may want to run.
PostPosted: Mon May 21, 2012 4:40 pm
by Partsman
Oops! I meant to post that on my build thread.
What is the best fix?
PostPosted: Tue May 22, 2012 12:47 am
by 8ball_99
The inside lights should be wired to the running lights on the trailer. Plug it into the truck and turn on your lights for the truck while the key is on. The lights inside should work. You are going to want to rewire them. Trace the wires from the lights to where they connect to the trailers wiring. They are probably just scotch locked. Remove the scotch lock and run a wire from their to your wall switch.. Then just run a power wire from your power center to the light switch. These trailers don't come with onboard batteries so the lights are always just tied into the running lights. With all the interior walls exposed it should be a very easy fix.
PostPosted: Tue May 22, 2012 7:14 am
by bigbendhiker
8ball_99 wrote:The inside lights should be wired to the running lights on the trailer. Plug it into the truck and turn on your lights for the truck while the key is on. The lights inside should work. You are going to want to rewire them. Trace the wires from the lights to where they connect to the trailers wiring. They are probably just scotch locked. Remove the scotch lock and run a wire from their to your wall switch.. Then just run a power wire from your power center to the light switch. These trailers don't come with onboard batteries so the lights are always just tied into the running lights. With all the interior walls exposed it should be a very easy fix.
I noticed in a previous post that you plan to install a/c. You should also plan and run the power for this now.That most likely means that you need to make plans for 110v AC. If that's the case you will also probably want additional outlets for other uses. My Dad always said, "You can never have too many outlets." Now is the time to install them. Much will depend on your intended uses for your trailer. There is great advice on electrical systems in the electrical section of this forum.
PostPosted: Tue May 22, 2012 12:02 pm
by Partsman
I am planning the bear minimum for power. One 110 and a couple lighter sockets. The trailer already has lights.
I guess I should do the 110 now while the wall is apart.
