Another insulation question please. Worried about rust.
We have the new CT, and it's time to act. Remove the plywood walls to insulate using a combination of Reflectix and foam board.
*Is it OK to apply the reflectix or foam board directly to the inside of the trailer skin between structural members, including the ceiling? Or do I leave space because of condensation causing rust?
*Which material should go toward the inner area? The foam board or the Reflectix?
*Are the doors practical to insulate? I would think that to not insulate them would be a mistake.
If I hard wire our trailer for 120V, I plan to use surface mount PVC conduit where I run wires.
Thanks, Don.
Thanks, Don.
