Hey TNTTT,
Here is my trailer build thread which is based on Gadgetman's (I have no where NEAR his ability to make cabinets or a friend to work pro bono.) All this work was completed in a weekend since next week we will be camping at the Carlisle, PA swap meet. As a bonus, pretty much everything I had sitting around the yard. The requirement is to be able to 1- pull in a Jeep TJ (lifted/locked) or 2-get 4 Yamaha grizzly atvs to fit.
<edit 042713> Well, it looks like I skewed from gadgetman's floor plan/living quarters/cabinet ability just a "little bit."
Anyway...
Base model Car Mate 8.5' x 22'
Twin 6000lb torflex axles
+ 6" height
+"get out door" on the opposite side
+4' v-nose for mpg/storage
Painted off-white/eggshell from the bare wood...
Railed both sides... 2 layers
Needed some storage... also ran 45ft of string LED light, for low amp. ext power needed...
Strap holder...
Ran a hard line out of 12/3 for the Honda generator, ran through the channel and custom tie down...
Tongue was 18" longer as per the sales rep since we had to worry about the tailgate vs the jack, now shortened to 6 inches, what a waste of 300.
A leftover DiamondBack low profile cab guard from a Colorado works great for storage and as a the light control box...
A little red neck with the signal stick...
Needed more storage and the micro is mounted up...
Manual vent mounted 4ft from the back...
Powered vent 4 ft from the front...
Linoleum the floor, 2qty, 8x12 sheets, perfect width, used carpet tape to hold it down.
Picked up a 18"x24"x7' cabinet from Home Depot, "scratch and dent" for $150 w/ tax vs $220+. Had to rebuild the back since the staples came out, fix the broken slider drawer (bent wheel) ** to be minwaxed ** Really wanted a 24" depth.
Secured it to the top with the 2x4 brackets (through bolted 2 per bracket, 4 brackets in all) and had it sit out from the "V" for the mini toilet.
Humm... How can I hide this and create privacy? I got it! Instead of bending rebar and welding brackets, I took a prebent piece of aluminum, 3 wire loom clips, an old bathtub privacy screen and bolted it in. Can't beat free.
Curtain open..
Need a laptop tray for when we are in the back sleeping or outside it. Took a piece of scrap, cut it 17"x17", use 2 brass hinges and bolt it up.
Open------------
Closed with a bungee----------
Current setup---
To be finished...
minwax/seal cabinet
find a 12" wide cabinet, for by the door
find a counter top to span the door to the V nose
