Hitch Receiver Extensions?
Postby BC_Explorer » Sat Oct 20, 2012 12:51 pm
The local parts store has a 14" hitch receiver extension on sale this week. With my 6x10 V-Nose trailer, there is not a lot of trailer tongue length which makes for mounting external items such as tool/battery box or propane tank almost impossible due to the short clearance between the trailer and the TV, especially on very tight turns. I would think with the extra receiver hitch length, this clearance problem would be somewhat relieved, but before I spend the money, I am looking for suggestions, and pros/cons on this.
Thanks
BC_Explorer
Images: 19
Re: Hitch Receiver Extensions?
Postby angib » Sat Oct 20, 2012 1:27 pm
They are a 'hitch receiver weakener' too, so you need to have a big margin of safety. I've heard reports of reductions in maximum tongue load to two-thirds or even to a half of the original receiver's maximum. Towing a teardrop, that's unlikely to be a problem but you need to be aware of the effect. It will also increase the leverage of the trailer on the tow vehicle, reducing its stability somewhat but, again, you probably are not near the limit with a teardrop.
Ooops, cancel some of the above - I've just seen you are talking about a cargo trailer which may not be that far off the maximum rating of your receiver.
angib
5000 Club
5000 Club
Images: 231
Postby roadinspector » Sat Oct 20, 2012 1:35 pm
Watch your tongue weight. According to Reese you will loose 1/3 of your tongue weight capacity with that. The farther you go back, the more you lose. If your tongue weight capacity is 500 lbs, it just dropped to 333 lbs. Plus when you move the hitch pivot point back it is easier drag your tongue or tongue jack, depending on your TV/hitch & CT setup.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby BC_Explorer » Sat Oct 20, 2012 2:23 pm
My CT has a GVWR of 3000 lbs and a recommended hitch weight of 10-15% of curb weight. The loaded weight of the trailer (as weighed on a scale this summer) is 2400 lbs. My new TV has a Class IV hitch with a ~1000 lb tongue weight rating. The TV has a 10,000 max towing capacity so I should be more then fine on the weight concerns.
BC_Explorer
Images: 19
Postby GarArnett » Mon Oct 22, 2012 8:55 pm
Had a 10" extension (its still there, just gave the truck to my son) on my 2002 Nissan Frontier. Used to tow a 6x10 cargo loaded with motorcycles and camping gear and race gear. Never had a problem towing the trailer with the truck. It is supposed to lower the tongue weight, but again, never a problem, and I usually had the trailer heavily loaded, long hauls - 400 to 750 miles one way - at freeway speeds 70+.
GarArnett
Postby Wolfscout » Tue Oct 23, 2012 8:47 pm
I have used one several times. My Extension is solid 2" as is my receiver mount. It's much more likely that my hitch will come off my TV before I have a problem with the extender back to the CTC.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby eamarquardt » Tue Oct 23, 2012 8:51 pm
Wolfscout wrote: ............. It's much more likely that my hitch will come off my TV before I have a problem with the extender...............
Yup, that's my concern and I think if the "hitch" came of the TV it would be a bit of a problem.
I'm just not convinced, unless the hitch is a class 3 or better and the trailer is small and light, that it's worth the risk.
Gus
eamarquardt
Images: 150
Postby Wolfscout » Wed Oct 24, 2012 2:07 pm
I meant that bit in a sort of sarcastic manner. ifyour hitch comes off.. it won't be because of an extender. mounted wrongly. or metal weakness perhaps.
Larry Fulmer, Jr.
CTC 2
Wolfscout
Images: 32
Postby eamarquardt » Wed Oct 24, 2012 3:09 pm
Wolfscout wrote:I meant that bit in a sort of sarcastic manner. ifyour hitch comes off.. it won't be because of an extender. mounted wrongly. or metal weakness perhaps.
I knew that. Just following your lead.
Gus
eamarquardt
Images: 150
Postby GarArnett » Thu Oct 25, 2012 9:49 pm
Gus
Personally, I don't tow unless its with a 2" square class 3 or 4, receiver hitch that is frame mounted. I just don't do bumper hitches, and don't really understand why you would have the little 1" square jobs I see on some small SUVs. Just doesn't seem to be worth it. And, no I wouldn't use an extension on one of the little things, just the 2" receivers.
GarArnett
Postby jeff0520 » Thu Oct 25, 2012 10:27 pm
Personally, I'd get some good quality ASTM 500 steel tubing and extend the trailer tongue before I tried some sort of reciever extender. Here's how I did it on the Command Post:
94771
93916
93915
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
