What do you think?
Earnest
Mud_Bug wrote:I have recently insulated my CT. In the beginning stages of planning my build I was looking at all alternatives to insulation. Cost, effectiveness, supplies on hand, and longevity of material used were all considered.
Cost: I found several different ways to get this task done. After reading and reading, investigating and probing...I found that to me, my best option was to use foil back foam board. Rust and rot were no where in my thought process until now. For $145 I purchased 15 sheets of 1" foil backed styrofoam insulation. Yes, it filled the z metal to its fullest.
Effectiveness: I wanted my build to be effective, practical, and go for "the long haul". In other words, I didn't want to have to re-insulate at a later date because I didn't do it correctly or cheaply. My supplies on hand were minimal, therefore I'm having to buy as I go to get this done. Again....cost on this build is a huge factor to me.
After reading this article, among many others, I'm tickled pink to know that my decision to use foam board will suit my needs very very well, I know it's done "right", and I will not have to worry about it again.
KevinC wrote:Mud_Bug wrote:I have recently insulated my CT. In the beginning stages of planning my build I was looking at all alternatives to insulation. Cost, effectiveness, supplies on hand, and longevity of material used were all considered.
I am thinking of using the same thing. It seems to be fairly cheap and looks like it would flex better around the curves of a teardrop. I may be wrong on the flex thing especially if you are using the thicker sheets like 1" or more. I thought of using several layers of the thinner stuff to help fit the curves.
Sorry... I am sure the flexibility issue is probably addressed in other threads. I have not researched it a lot because I am not that far into my build.
Thanks for your thoughts.
roadinspector wrote:KevinC wrote:Mud_Bug wrote:I have recently insulated my CT. In the beginning stages of planning my build I was looking at all alternatives to insulation. Cost, effectiveness, supplies on hand, and longevity of material used were all considered.
KevinC,
I do like your idea of multiple thin layers for your purpose.![]()
Earnest
