New trailer order question
Postby Suwannee Dave » Thu Dec 27, 2012 7:20 am
Has anyone ever ordered a new trailer and had the builder leave out the interior plywood liner? Seems like this would save some time in a conversion build. Would it make the trailer structurally unsound for towing home?
Suwannee Dave
Re: New trailer order question
Postby pvangel » Thu Dec 27, 2012 9:45 am
I asked that question to ATC and they said they would not ship without the plywood, that was an all aluminum trailer if it makes a difference. I just took all the plywood off mine and really the only thing holding it together is the thin skin on the outside, aside from where the tubes are welded together.
pvangel
Postby H2Nut » Thu Dec 27, 2012 9:51 am
When I ordered mine the trailer guy stated the same thing - the plywood is part of the structural support of the trailer.
H2Nut
Images: 22
Postby pvangel » Thu Dec 27, 2012 11:53 am
Mine was not a big deal to remove, probably and hr or so and it was off
pvangel
Postby OverTheTopCargoTrailer » Thu Dec 27, 2012 12:20 pm
My advice if you wanna insulate, leave the plywood,
add foam panels and a second layer of plywood, floor ,
Walls & ceiling
Postby Prem » Thu Dec 27, 2012 1:31 pm
Depends on if the ribs are all welded together (steel or aluminum). If they are NOT welded, then yeah, the interior plywood is really providing structural support. It also depends on whether you want to keep the trailer from gaining unnecessary weight. (Increasing weight is hard on automatic transmissions, even in 1-ton trucks. Don't "axe" me how I know, just never drive steep roads and downshift as a form of braking. Your torque converter fins can come apart and trash the clutch cluster.)
$> $> $> <---each of those is a thousand bucks
If you find that the ribs are not all welded top and bottom, you could remove all the plywood and cross-brace the ribs with metal strap attached to the ribs with flathead machine screws, rivets or self-tapping screws. Then you can put foam weather stripping tape over the ribs, but not over the fasteners. It levels everything out so you don't end up with bowed, interior plywood on top of every fastener. If you're really thinking ahead and want longevity for your work, you seal both sides of the plywood and the end grain against humidity (with a non-toxic sealer) so warpage doesn't become an issue. Winter is the worst, because sleeping in it causes lots of condensation inside the walls. :frightened:
Fore wat itz woyth,
Prem
My goal...
...is to live in a trailer.
Prem
Images: 144
Postby OverTheTopCargoTrailer » Thu Dec 27, 2012 4:32 pm
Prem
How well does a dehumidifier work inside the trailer in winter time ?
It should help with that & also heating both, I just got one for 25 pints at 410 watts
will report back in a week or so what the results are :NC :NC
Postby Prem » Thu Dec 27, 2012 9:23 pm
I'm hoping you will tell me. :thinking:
(All they sell around here in the winter is humidifiers. lol. You can't find a dehumidifier for sale here in the summer either, because our humidity is often in the single digits.)
My goal...
Prem
Images: 144
Postby rando18 » Fri Dec 28, 2012 12:12 pm
OverTheTopCargoTrailer wrote:My advice if you wanna insulate, leave the plywood,
Walls & ceiling
I've thought that was a good idea myself.
If you find that you are thinking like me,
be scared. Rando
rando18
Postby OverTheTopCargoTrailer » Tue Jan 29, 2013 6:40 pm
Actually I just ordered a new trailer that has wood walls & they agreed to install the plywood on the exterior no extra charge.
So it screwless metal siding, then the plywood, then wood wall studs -
from there I will add 3"+ of foam insulation and more plywood to the interior
Jerry
Postby DTCOOPER » Wed Jan 30, 2013 3:53 pm
OverTheTopCargoTrailer wrote:Actually I just ordered a new trailer that has wood walls & they agreed to install the plywood on the exterior no extra charge.
Jerry
Jerry,
How does the screwless skin attach to the wood ?
Because I have a constitutional right to, that's why!!
2007 Tundra Tow Vehicle
2004 Road King for riding
Kawasaki mule, 4 wheelers, and other toys for playing!!!
DTCOOPER
Postby 8ball_99 » Wed Jan 30, 2013 7:38 pm
Glue or double sided tape. Which works pretty good inless you ever have to replace a piece of the skin for any reason. The the screwless sucks because you will destroy the metal trying to remove it.. Since its overlapped front to rear if you damage a rear corner this could be a big problem.
8ball_99
Postby OverTheTopCargoTrailer » Thu Jan 31, 2013 4:41 pm
There is a product by 3M called 560 is a glue / epoxie ?
Come on 8 ball , don't scare me ...
I can get a sheet of 48" x 8 ft for $63 -
worst case if you do the whole side it's $300
Or just get another new trailer :-))
