solar
solar
Postby jwhite » Wed Jan 02, 2013 11:16 pm
I have decided to invest in some solar panels for my trailer and also my house, any advice on what to use and what to expect?
I have watched youtube videos and it looks more technical than I am ready for.
I would like to get enough panels that I could run a 8000 btu window AC dureing the day off the panels and then run my generator at night.
I am wondering if I should find a local company that does this so it's done right, it looks like you can ruin your batteries if you don't know what your doing?
jwhite
Images: 46
Re: solar
Postby Shadow Catcher » Thu Jan 03, 2013 7:11 am
Running AC on solar takes a lot of power/panels!
For solar expertise there are a number of us on this forum http://www.wind-sun.com/ForumVB/forum.php
You are looking at in excess of 8 amps starting surge for an 8000 Btu 120V AC.
Re: solar
Postby OverTheTopCargoTrailer » Thu Jan 03, 2013 11:09 am
If you read my form or blog under the same name I am running a 5,000 btu AC with 840 watts solar during the day time.
The solar puts out 670 watts max & the AC uses about 550 watts.
If your just cooling one room , it's cheaper to insulate more & maybe only use 5,000 Btu AC unit.
For what you are looking for your talking at least a $10,000 project
Re: solar
Postby jwhite » Thu Jan 03, 2013 1:05 pm
Thanks for the link to the solar board that is just what I need to learn more, I want to invest in a solar system for my house and I thought I could start and learn would I need for the trailer.
I was watching a youtube video and this person was running a AC but it didn't go into details so I wasn't sure if it could be done?
I am starting to think for my house I should go to a company that does this to have it done right, and it looks like it would be expensive but probably worth it in the long run, maybe after I read the solar board for a while I may change my mind?
When I bought the AC for my trailer I found a 5000 btu on sale for 100.00 after I bought it then I went to lowes and found a 8000 btu AC for 160.00 so I have 2 I figured I could use them both, I put the 8000 in the trailer and I haven't used the the smaller one but I could swap it out and put the larger one in the house?
jwhite
Images: 46
Re: solar
Postby Shadow Catcher » Thu Jan 03, 2013 5:20 pm
It is very difficult to make a good return on investment on solar unless it is necessary i.e. off grid remote location, or in states where it is heavily subsidized. It is even difficult to justify in a trailer unless you will be doing a lot of boondocking and are obsessive about not having a generator running, which is where I am. Having said all that you can, with used panels or the panels that will be coming in the future get to a more reasonable ROI.
If you check on the wind and solar forum you will find that there are many clueless and dangerous solar installers.
Re: solar
Postby OverTheTopCargoTrailer » Thu Jan 03, 2013 9:15 pm
Hey Shadow Catcher
"""If you check on the wind and solar forum you will find that there are many clueless and dangerous solar installers.""""
Stop talking SMACK about me :D :D :D :D :D
ROTFLOL
My 840 watt solar trailer has not burned down yet :applause: :applause:
I just doubled my insulation with a second layer of blue Smurf board :R
soon I will be able to heat with a match & cool with a ice cube
http://overthetopcargotrailer.blogspot.com/
Re: solar
Postby bdosborn » Sat Jan 05, 2013 5:03 pm
jwhite wrote:I have decided to invest in some solar panels for my trailer and also my house, any advice on what to use and what to expect?
Forget about running an A/C unit off of solar panels, its just too expensive and you probably don't have enough roof top area for all the panels you would need. The first step in designing a PV system is to figure out how much power you think you'll use in a night. Here's a link:
Solar Linky
I can't emphasis how important this step is, all though no one (myself included) seems to do it. You'll probably end up buying things twice (like I did) if you don't understand what you're designing towards . We can size your panels, controller and battery after you figure out your usage. Wiring is easy, you can probably do it yourself with forum help.
Images: 806
Re: solar
Postby jwhite » Sat Jan 05, 2013 5:36 pm
Thanks for all the input,I have been reading the boards and have been watching youtube videos.
one of the best one's I saw was a guy who's set up generates 800 watts and from what I read that the small window AC's use 400 watts so I guessed that would work but I didn't think about the start up?
I think the system he has built looks like what I need and it cost him 5000.00 I don't mind the cost but I am not sure how to put it all together and have it work right.
I think I will go to a local solar company and talk to them after I do more reading and have a better idea what to expect.
jwhite
Images: 46
Re: solar
Postby OverTheTopCargoTrailer » Sat Jan 05, 2013 8:26 pm
Remember my ac is running on the solar, now with the newer insulation it will be
TWICE as COLD !!
But its good you keep telling others don't do it.....
I don't want another 100,000 solar trailers out there :D :D
Jerry
PS - jwhite
GO TO BRUCE - he is the Forms SOLAR GURU :D :D :D
Re: solar
Postby GuitarPhotog » Sat Jan 05, 2013 9:23 pm
Sh*t, most of us don't have that much tied up in our trailers in total, much less in a PV system to power it.
If you have more dollars than sense, go for it. Otherwise listen to Bruce!
<Chas>
:beer:
GuitarPhotog
Images: 55
Re: solar
Postby jwhite » Sat Jan 05, 2013 10:45 pm
My original post I said I was going to invest in solar for my trailer and my house ?
I live in south GA and get alot of sun and have been through many hurricanes over the years.
When hurricane Kate roared through power was out for 2 weeks,I would like to be prepared incase that happens again.
The youtube I was watching this guy designed his system so so he could take down the solar panels and store them if you knew a
hurricane was coming and I thought that was a good idea.
If I could take a couple panels with me if wanted to take them camping that would be evan better.
jwhite
Images: 46
Re: solar
Postby OverTheTopCargoTrailer » Sat Jan 05, 2013 11:56 pm
Hey chas
I have a $5k 100% all glass tile shower in my trailer
Why do you think it's called
OverTheTopCargoTrailer. :D :D :D :D :D
PS - Bruced helped me with the solar :D :D
Besides jwhite has a harmless u tube video watching habit & wants to learn how to do stuff
He wants solar system to remove before the hurricane & then reinstall
To give him power till the city gets it back on :applause:
Re: solar
Postby bdosborn » Sun Jan 06, 2013 12:14 pm
jwhite wrote:My original post I said I was going to invest in solar for my trailer and my house ?
You might as well get started on what your energy usage will be as any good PV installer will start there.
Images: 806
Re: solar
Postby jwhite » Sun Jan 06, 2013 12:59 pm
http://www.youtube.com/watch?v=pedyMd5mGg4
This is the video that I am looking at that I think would work for me, it looks like he has done alot of research.
I live in a hot part of the country and I use wood heat in the winter so the only heavy electric use is in the summer running AC.
When I built my trailer I wanted to use solar but it was just easier to run my Honda 2000 generator,now I would like to see if I could learn about solar on a small scale starting with the trailer to run a small AC in the day to save me from running the generator 24 hours a day.
I think the solar system would be a good investment in the long run,I also think I could live off the grid if I had to, I would need to change some of my appiances to propane and do a couple other things, but living without AC in the summer would be impossible.
jwhite
Images: 46
Re: solar
Postby bdosborn » Sun Jan 06, 2013 1:26 pm
You could do it that way; he's on the right track but his installation methods are terrible and doesn't come close to meeting code. Also, BZ controllers are universally panned over at NAWS. Lets start from scratch, what A/C are you going to run?
Images: 806
Users browsing this forum: Google [Bot] and 2 guests
