After a cold, and constantly wet (rainy) winter (and a few months to go yet), the interior walls of my CT did not survive unscathed. The walls are melamine coated fiberboard and are now wavy and bowed significantly in some spots at the joints between the screws which are spaced at 12" intervals. The ceiling is FRP paneling from Home Depot which I thought would be a good product but I am very dismayed to see that it too, is wavy and distorted.
Needless to say, that although I wanted to change the interior layout this spring, re-doing the interior walls and ceiling was not part of the plans and they now need to be replaced. Before I go through this again, can anyone recommend a different product to use. I was thinking of going to with a quality then painted plywood this time around but not too sure if this will be ok or not.
Regardless of what product recommended and ultimately used, next winter I will be putting a small electric heater on a timer that will come on a couple of times per day for about 1/2 hour. Hopefully this will prevent a repeat next winter...
