Deep cycle battery location
Postby MXD » Tue Feb 05, 2013 1:27 pm
Hello all,
I pulled the trigger and ordered my new Car Mate Custom Cargo 7x16 so you will be seeing a build thread with pics once it arrives in a few weeks. The trailer will be for MX racing but it will have base and overhead cabinets, a shower, some sort of fold away or portable bedding and all kinds of other stuff.
For now, my question is this, can I put the deep cycle battery in the trailer in one of the base cabinets or does it have to go on the tongue? I have heard that there is a possibility of dangerous fumes and I have also heard that is not true. Does anyone have a definitive answer? My only concern would be while sleeping as during the day the doors are all open and the vents are all open as well.
Thanks
MXD
Re: Deep cycle battery location
Postby GuitarPhotog » Tue Feb 05, 2013 1:44 pm
If you are not charging the battery, there is no hydrogen given off.
Better is to get an AGM (Absorbed Glass Mat) battery that vents only to prevent catastrophic explosion.
You can put a battery anywhere you want, but if it's a conventional wet-cell battery, you should vent it to the outdoors.
<Chas>
GuitarPhotog
Images: 55
Postby MXD » Tue Feb 05, 2013 1:55 pm
So, a battery like this would be ok to mount in a cabinet in the living space?
MXD
Postby droid_ca » Tue Feb 05, 2013 2:15 pm
I'd try to mount them as low and as center to the axle as possible if at all possible you could disguise the battery box with a counter of sorts for ether your tools or kitchen
“Fide Canem”
viewtopic.php?f=5&t=52816
droid_ca
Images: 176
Postby 8ball_99 » Tue Feb 05, 2013 3:44 pm
Mine are in a hatch in the floor back by the axles.. You can mount them inside you just need to vent he cabinet.. It would also be nice if the cabinet was some what sealed off from the living area.. Thats how I did my hatch.. I put a gasket around the door and put two vents to the outside.. One low and one high.
8ball_99
Postby Shadow Catcher » Tue Feb 05, 2013 3:46 pm
More like one of these http://www.lifelinebatteries.com/rvdeep ... teries.php
They are true Deep Cycle, the marine maybe not.
Postby eamarquardt » Sun Mar 17, 2013 6:35 pm
21 million Volkwagen Beetles (type 1) were produced with the battery inside the passenger compartment and I've never heard of explosions or fires. I did have the voltage regulator fail on my 67 though and the sulfuric acid fumes made me cough.
My Chevy Traverse has a sealed battery under the floor behind the front passenger's seat.
Gus
eamarquardt
Images: 150
Postby roadinspector » Mon Mar 18, 2013 10:17 pm
eamarquardt wrote:21 million Volkwagen Beetles (type 1) were produced with the battery inside the passenger compartment and I've never heard of explosions or fires. I did have the voltage regulator fail on my 67 though and the sulfuric acid fumes made me cough.
Gus
Talk about a trip down memory lane!! :shock: You are absolutely right!! We had more than one growing up and never had any problems. Never did smell any fumes or have any problems except had to replace the floor pan on a 58 bug once due to old age and a couple of accidental overfills. :duh:
Thanks,
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Postby Shadow Catcher » Tue Mar 19, 2013 6:51 am
One of the reasons there may not have been much danger with a VW Type 1 is that the generator put out 30A, on a good day and that minus what ever you were powering, like the engine and lights...
I had a Baja Bug and no the battery never out-gassed that I know of.
100270
Postby eamarquardt » Tue Mar 19, 2013 9:45 am
Shadow Catcher wrote: that the generator put out 30A, on a good day and that minus what ever you were powering
I've never seen a battery charge at a rate of 30 amps. Usually 6 or so.
Gus
eamarquardt
Images: 150
Postby MXD » Tue Mar 19, 2013 10:51 am
I thought I needed an AGM battery but the guy at my local batteries plus said that this one is sealed and would be fine for putting in my living space. Is he on point or clueless? I'm definitely clueless :lol:
http://www.batteriesplus.com/product/33 ... p-27M.aspx
MXD
Postby dustboy » Tue Mar 19, 2013 11:11 am
Mazda Miatas have the battery in the trunk, and it is spec'ed as a sealed AGM. My mom's old Audi had it under the passenger seat, not sure what type or whether it was ventilated. Some of those cars literally had a "hot seat" where a person of sufficient heft could touch the seat spring to the terminals...ZAP!
I'm probably going to end up placing mine inside, I thought about a tongue box but I feel like it's a little vulnerable where it is parked overnight (folks round here like to steal batteries and collect the $8 core deposit). If you're worried about it creating too much hydrogen you could always crack a window any time it might be charging (i.e. while towing). My trailer will never be that well sealed anyway.
dustboy
Images: 10
Postby dustboy » Tue Mar 19, 2013 11:13 am
MXD wrote:I thought I needed an AGM battery but the guy at my local batteries plus said that this one is sealed and would be fine for putting in my living space. Is he on point or clueless? I'm definitely clueless :lol:
I don't see anything in the description about that being sealed!
My buddy owns 3 Batteries Plus, I'll ask him.
dustboy
Images: 10
Postby MXD » Tue Mar 19, 2013 1:10 pm
That would be great, thanks.
MXD
Postby roadinspector » Tue Mar 19, 2013 10:00 pm
I am running an AGM battery that is designed for server backup and solar systems. It is sealed and designed to be stored inside of offices. Love it!!
Earnest
roadinspector
Images: 127
