Electric - Converter question
Postby drcurran » Fri Jul 19, 2013 8:17 pm
Purchased a used converter some time ago. Seems like a pretty simple hook up. Easy to see where the 110v is connected. Has a ground strip - no problem. Out of the back it has three wires two white and one red. I hook the two white up to lights and fan (12v) and they work fine. I was thinking the red wire would go to the battery for 12v power when not "plugged in". Does that seem correct? Any and all help is appreciated. BTW the converter is not longer made and it did not come with any instructions. Thanks!
"I'm not as good as I once was, but I'm as good once as I ever was."
TK
drcurran
Images: 20
Re: Electric - Converter question
Postby hankaye » Fri Jul 19, 2013 9:23 pm
drcurran, Howdy;
Got a few photos to show what you are dealing with?
A few of it from different angles would be a big help
for anyone to help you better. Eliminates the guess work.
hank
hankaye
Postby drcurran » Sat Jul 20, 2013 8:07 am
I can't remember how to post a pic, and can't find "how to" in the FAQ section.
TK
drcurran
Images: 20
Postby Quadriderdad » Mon Jul 22, 2013 8:28 am
Red should go to your 12 volt fuse panel. The whites should 12 volt and/or 110 volt grounds. Is there a terminal lug all by itself?...definitely need some pics to be more helpful. Seems odd that you would have power using both whites :?
Quadriderdad
Images: 51
Postby Quadriderdad » Mon Jul 22, 2013 8:30 am
drcurran wrote:I can't remember how to post a pic, and can't find "how to" in the FAQ section.
If you put up a pic of it in your gallery I'll help ya post it if you like.
Quadriderdad
Images: 51
Postby drcurran » Mon Jul 22, 2013 6:58 pm
Thanks for the offer of help. I can't remember how to put pics in my gallery! Help!
TK
drcurran
Images: 20
Postby Quadriderdad » Mon Jul 22, 2013 10:22 pm
It is pretty cumbersome...I'll try to help. First in the upper area just below the blue banner and to the left you should see in small letters 'User Control Panel'. click on it then you will see several blue tabs. Go to 'Galley' on the right end. Next go to 'Manage Personal Albums' on the left...then in the middle click on 'Upload Image'.
Simple huh! :? :cry: :shock: :x :lol:
Quadriderdad
Images: 51
Postby drcurran » Tue Jul 23, 2013 7:33 am
Thanks Quadriderdad I think I got it. I've tried to post a front and back pic of the converter. On the back you can see a ground block, and the three wires (2 white and 1 red) the 2 white are controlling the 12v lights and the roof vent fan. Not sure what the red is for. 110184110183
TK
drcurran
Images: 20
Postby drcurran » Tue Jul 23, 2013 7:35 am
Sorry the 3 wires in question are 2 blue and 1 red. Blue control lights and fan. Don't know what the red is for. Thanks for any help.
TK
drcurran
Images: 20
Postby GuitarPhotog » Tue Jul 23, 2013 11:12 am
I would be willing to guess that the red is for the battery circuit.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby OverTheTopCargoTrailer » Tue Jul 23, 2013 1:02 pm
Chas i'm willing to double down on your guess
But if the pictures were larger, my microscope was better or my eyes weren't failing....
I could throw in my own opinion :lol: :lol:
Postby Quadriderdad » Tue Jul 23, 2013 1:55 pm
Who is the manufacturer on the label?
Quadriderdad
Images: 51
Postby drcurran » Tue Jul 23, 2013 2:28 pm
Sorry for the eye strain. Best I could do. The mfg. is Carson and they no longer are in the business. When I first got it I tried to get a manual, but no luck. If the Red wire goes to the battery, does it charge the battery when I'm hooked up to "shore power" and then does it supply 12v power to the trailer when I'm not on "Shore Power"? Thanks all!
TK
drcurran
Images: 20
Postby GuitarPhotog » Tue Jul 23, 2013 3:43 pm
I would assume so, that's the way other converters work, but since we know nothing about this particular converter, your guess is as good as mine.
Hooking it up and measuring some voltages would be my next step.
<Chas>
:beer:
GuitarPhotog
Images: 55
Postby roadinspector » Tue Jul 23, 2013 7:17 pm
I LOVE A GOOD SMOKE TEST!! :cigar:
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
Users browsing this forum: Google [Bot] and 5 guests
