by orcadigital » Mon Aug 12, 2013 9:23 am
Hello everyone. First time poster though I have been lurking and reading up on a lot of the excellent build threads here. Finally decided to sign up, and post my project and probably solicit for some advice throughout.
This is a little different from the normal camper builds here. I have been a homeowner for a little over a year now, and have found the need to carry larger items (ladders, lawn mower, drywall, etc) then my SUV can handle. A trailer seemed to be the answer. Also, one of my hobbies is racing remote control cars. Most of the outdoor offroad races we go to offer little to no shelter, and only sometimes power. We have done the pop-up tent thing, but as I was looking for trailers anyway, decided a dual purpose was the best way to go. I ended up finding a 2001 6x12 Pace American for an excellent price on Craigslist. It has some dents and is not very pretty, but is structurally sound and was within budget. It came pretty basic, with luan interior walls, 2 shelves built into the front, and 3 lights wired in to an AC plug with a switch. No DC lights other then exterior marker/brake/signals. Took it out to the track a couple times and began to get a feel for what it needed. and have spent some time recently in a friends already set up 6x10. Also important to me was a shorter trailer. It is a 5.5' interior height, which makes my goal of getting it in the garage a possibility.
Project outline:
Lower trailer enough to fit in garage
Install interior and exterior lighting
Redo interior wood panelling and insulate
Install AC and DC power system
Install Air Conditioning
Install front cabinets
Fabricate removable workbenches
Install rear freezer panelling
Carpet flooring
Etrack and finished walls
There is probably more, but that is the general plan. To date, I have stripped out the interior and the AC power that was in. I have also replaced the axle with a brake capable 4" drop axle with 14" wheels and new fenders. I have some purchased items and will continue with assembly as time permits.
Currently awaiting installation:
30 AMP shore power/generator inlet
WFCO 55 AMP Convertor
5050 BTU Window Air Conditioner
Wiring and outlet hardware
Front cabinets and possibly counter
RV style door latch for side door
Next plans are to remove the etrack from the floor and fill the holes. Next will rough in the wiring for AC and DC including interior and exterior outlets, power inlet, and location of convertor box. Then will insulate, put in 1/4 plywood walls, and install the front cabinets. I need to remove the vent from the roof, install new side vents, then insulate and put up 5mm luan on the ceiling. Still trying to determine exactly how to do the wall mount air conditioner. Currently debating between a partial removable false wall in the rear or in the front on slides then can be slid out when used. Interior lighting will be DC (LED strip lights is the current plan) powered from the WFCO. I will always have access to shore power or a generator so a battery is not in the plans today, but might be later. I went with a much larger convertor for the RC cars. The chargers we use for the batteries are all DC powered. It seemed silly to run AC and convert back to DC with power supplies when I am already putting in DC power. Need to find a nice way to mount 4mm banana jacks into the wall that will not protrude. The 30 amp inlet is the marine twistlock style (which I know was not recommended), but I already have a 25' cable and adapter to regular 15 amp service. It is beefier then any extension cord and I wanted to put in more then I needed to account for any future changes (larger AC, running a compressor, etc). I plan on running 20 amp service to wherever the AC will be installed, 15 amp outlets inside (GFCI) and 1 15 amp outlet on the outside (passenger side, also GFCI) for either a compressor or friends pitting in a pop up tent against the side of the trailer.
Sorry for the long intro, but attached are some pictures of first getting it.
Thanks!
Grant
- Attachments
- Inside when I got it
- small trailer 02.JPG (118.13 KiB) Viewed 6946 times
- Outside bringing it home
- small trailer 01.JPG (164.18 KiB) Viewed 6946 times
