Generac vs Honda generators
Does anyone have experiences with Generac or Honda portable generators n the 2000 watt size?
or t n ttt for short (tnttt.com)
https://www.tnttt.com/
lrrowe wrote:From everything I have read, the Honda EU2000i is the way to go. And from personal listening experience, they are very very quiet.
I want to get one, but my budget today says I have to wait till the CT is built and it is time for the better upgrades. I have seen them a month ago for $899 on sale. But now the lowest I can find is $999.
For this fall's hunting season in the wilderness, I am going to get this Champion listed below for $199 at Tractor Supply. The cons are that is is less in wattage, noisier, bigger and does not have an electric start. And it is only about 50 lbs and I can lift it to locate it away from the camp site. But I figure that I can sell it later and not get hurt if I do not want it. And TS has a 30 return policy so if it does not give us enough light, charge a few batteries and run a coffee pot to my satisfaction or if it should fail for some reason, I will give it back.
http://www.tractorsupply.com/en/store/c ... -compliant
But I am going to get a EU2000i one of these days.
dpjeansonne wrote:tnriverluver
Do you know about Champion's power quality? I have read that the inverter generators are much cleaner for electronic loads.
Also what I saw was that Champion was in the low 70's db noise range which seems significantly above H and Y. This may not be your personal experience though.
On the 2000i the fuel shutoff is incorporated into the on/off switch. Or the on/off switch is incorporated into the fuel shutoff valve. One of those.MtnDon wrote:But I like the fuel shut off on the Yamaha... think it's missing on Honda. But then the H carb bowl is easy to drain IIRC.
One thing I do like about H and Y is that there are dealers all over the place in case you need something.
GerryS wrote:The advantage of a separate shutoff is you can run the carb bowl empty...not just restricting fuel from the tank...
MtnDon wrote:GerryS wrote:The advantage of a separate shutoff is you can run the carb bowl empty...not just restricting fuel from the tank...
That's it!! I just didn't recall the details.But doesn't the H have an easy drain the bowl method?
I still love my Yamaha's.
tnriverluver wrote:lrrowe wrote:From everything I have read, the Honda EU2000i is the way to go. And from personal listening experience, they are very very quiet.
Do a little searching and get the Champion 3000-3500 watt with the wheel kit. You can find them from $279-299. They are fantastic and reasonably quite for that type of generator. Mine has many hours and runs better (and much quieter) than my similar type Honda 3500 watt. I can often get 18 hours out of a tank of gas also. Note that the 3000- 3500 watt 3500-4000 Champions are the same genny with sometimes different plug outlets available. They just relabel the wattage for the retailer.
