small cargo door
small cargo door
Postby wtcreaux » Thu Dec 19, 2013 10:36 pm
Has anyone put one of these in or does the factory need to do this?? This door would be like Aunt Barb's trailer for AC slider.
Thanks
wtcreaux
Images: 211
Re: small cargo door
Postby Rainier70 » Fri Dec 20, 2013 8:01 am
I know that some have put them in, but I can't find an example of one to help you out. I think it was a case of getting the prebuilt door and then the framing for it. Hopefully someone who has will see this. If not, search in here for things like battery box, propane locker, etc besides the ac. Good luck.
Rainier70
Images: 244
Postby bc toys » Fri Dec 20, 2013 8:14 am
to bad you are not close to Las Vegas Nv i got a cargo door I could help you out with.
bc toys
Images: 42
Postby roadinspector » Fri Dec 20, 2013 9:25 pm
Are you refering to one like this?
110724
If so check my build out. I just framed it with 1"x1" square tubing like the windows.
Earnest
Dadgum it! I cut that board 5 times and it's still too short!
2001 quad-cab Dodge Cummins 3/4 ton camper special, 16x7x7 CT work in progress toyhauler, 01 HD Ultra Classic, 98 HD Heritage Softail, 88 HD 1200 Sportster. viewtopic.php?f=42&t=51510
roadinspector
Images: 127
