I use the super-clean, super-simple, disposable-anywhere PETT system with WAG bags. You can see an example here
http://www.amazon.com/Cleanwaste-GO-anywhere-Portable-Toilet/dp/B001TKGAKO/ref=sr_1_1?ie=UTF8&qid=1387765636&sr=8-1&keywords=pett+portable+toilet. Google ("PETT porta potty") has dozens of images, reviews, and tons of places to buy at various prices. Here's the Bass Pro link.
http://www.basspro.com/The-PETT%28Portable-Environmental-Toilet%29/product/45413/?hvarAID=shopping_googleproductextensions&om_mmc=shopping_googleproductextensions&kpid=45413%26adc=pg_315_11126_5282bc6ee4b006f67e955387_34345653031I like it because you use it, zip it up, and throw it away. All approved. Used this system for years on overnight river trips too. Once you seal the bag, its odorless and no germs are going anywhere. Comes with a bit of dry chemical in the bag. The framework (seat) itself folds up out of the way nicely, is quick and easy to set up for use, and sturdy enough for most. I haven't even considered anything else after getting one of these. Previous experience with ammo boxes w/seat, 5 gal. buckets with seat and litter/dry chemicals. If you aren't going for full-on plumbing with a waste tank, this is my recommendation. And, unless you have a lot of users several times a day, the WAG bags are much easier to deal with than finding and using a dump station and hose. Here's a description:
"Disposal issues Resolved! Easy to use. No assembly required, sets up in seconds. Same Height and Size as a Standard Toilet. Folds into Briefcase Size with Dimensions of 19" x 14" x 5". SANITARY: Utilizes degradable waste bags (WAG™ bags) that gel waste, neutralize odor and begin the decay process, which make this system spill proof and hygienic. Special design of seat flange keeps outside of waste bag. clean STABLE: Three-leg design for stability on uneven terrain. LIGHTWEIGHT: Weighs only 7 lbs"
"The Wag Bag by Cleanwaste is the most sanitary, convenient, portable toilet solution available - complete with toilet paper and hand sanitizer. Prevents spread of disease with no spills, splashbacks or waste contact to provide easy waste management for large scale operations. Our toilet kit is the ONLY biodegradable solution that traps, encapsulates, deodorizes and breaks down waste with a NASA-developed gelling agent. Use it, seal it and toss it as normal trash."
Ebay has the bags for less than $1.00 each. Under a dollar a dump! WELL worth the convenience and cleanliness for me.
I have no commercial or other interest in this product other than when I need to do my business!
