RWH wrote:Thanks guys. I know I am a new guy on the boards here, but believe me, I have been reading these boards for quite a while now. These boards are a treasure trove of information and I am so happy I found you guys.
Of course, I am having the same problems everyone faces with a conversion such as these. For instance, I have the walls and ceiling insulated, easy enough, but what to do about the floor. Do I insulate the exterior side? Hmm.. I think I will try sandwiching the insulation as a subfloor using spacers for rigidity. Then use some type of floating floor as a finished floor. This way I can just simply weather seal the belly of the beast and not do the belly crawl trying to fasten foam board to the under carriage. Plus I think there may be moisture issues, if I do.
I picked up a shower stall today so hopefully I can get started on the build soon.
Getting excited.
First question:
I read somewhere in the forum that there are better inverters than others but for the life of me, I can't find it again. I remember some people were complaining of fan noise. Anyone know a good middle of the road inverter brand that will do the job and be quiet at it in the process?
WOW RHW
Your build is really smoking - world record pace. I used Dow blue board on the floor as it holds 15 psi - but your idea with spacers is also Excellent as its 50% or more cheaper and white foam smashes flat , most here 96% would rather die then loose 1" on the inside - BUT IT'S THE ONLY WAY TO GO , I have 2.5" floor, 3" walls and 4" denium in the ceiling. Doors have 1.5" Dow blue board.
I like the Magnum inverters PSW or MSW from 600 watt & up , as I have 2100 watt solar they are EXCELENT. -
Also they work as a EXCELENT quality battery charger & pass through when connected to shore power
The fan is VERY QUIET , is off most of the time, costs start around $600 and up. I have a 1500 MSW & the 1000 PSW
To get them to equalize the batteries you need the $185 control panel well worth the cost.
Morning star makes a great pure sine inverter NO FAN ,- ZERO NOISE, I have 3 of those - EXCELENT for everything , cost $225.
Good luck.
Check my blog
OverTheTopCargoTrailer
