MtnDon wrote:The combustion of a gallon of propane produces approximately 25 ounces of water as water vapor. That can and will condense on any indoor cool surface. That alone should provide a hint as to why any propane fueled portable heater is a bad idea.
Not to mention the hazards of possible CO production and the depletion of O2 in the interior as the propane burns. I know these heaters all come with warnings about leaving a window open partially to counter those things. I have friends who came very close to a death experience because of an unvented appliance coupled with dead batteries in the CO monitor they had.
We will be using a Propex heater if we decide we need interior heat. Or I'll be trying my experiment with using heat from the water heater circulated through a radiator by a small DC pump and small DC fan.
lrrowe wrote:MtnDon wrote:
Jerry,
As stated before, I want to test your idea out but I have no real way of doing it now.
Bob
MtnDon wrote:In general attempting to heat anything with low voltage DC is impractical, even with a large battery bank.
Many portable household 120 VAC electric heaters use about 1500 watts. If the element was manufactured to run on 12 VDC and it was to produce the same amount of heat it would still consume 1500 watts. Watts = volts x amps.
Lets pick a couple of golf cart batteries as a power source, because I like them. Two of them at 6 volts are connected in series to make 12 VDC. Wired like that a typical pair will have about 220 amp hours capacity. Multiply 12 volts x 220 amp-hours and we get 2640 watt-hours. That how much total capacity we have. But it is bad practice to run the batteries down past 50%; it shortens their life. So we really have 1320 watt-hours capacity to work with. BUT that is at the 20 hour rate. If we take 20 hours to draw the 1320 watt hours we could get that much total out of the batteries safely.
The heater uses 1500 watt-hours though. 1320 capacity divided by 1500 use = 0.88 hours available, or about 52 minutes.
BUT when the batteries would be discharged that rapidly under high load their actual capacity drops. So the batteries might only last 30 minutes at a high rate of discharge. That is a guess.
However that does give an idea of how long a simple battery setup would last. A single RV/Marine 12 VDC battery would most likely give half that and be useless, ruined after the first season.
{{ I have a background that includes some off grid PV experience. }}
