removing plywood
removing plywood
Postby Banjo » Mon Apr 07, 2014 2:47 pm
I don't know if this will help anybody or not, but for those of you that are trying to remove plywood from the walls that have those famous useless nails as fasteners , I use a 3/8 plug cutter that you can get at Lowes or other box stores . carefully start it and when you get it to cut it will go around the nail head and either go all the way or 1/2 way and then you can pop it off . Takes a little work to get it started but you can save the plywood . I don't care about the big hole as I will rescrew it in a different place and use thin panel over it . Bob
Banjo
Images: 5
Re: removing plywood
Postby Rainier70 » Mon Apr 07, 2014 3:48 pm
Nice solution.
Rainier70
Images: 244
