screen door options for CT?
Postby MMOLLECK » Mon Apr 21, 2014 9:26 am
Im trying to figure out, where to find a screen door for my enclosed trailer. My trailer has a 36 inch door on it, and I can't find one anywhere! Does anyone have any ideas? I thought about calling the factory, but with my budget, I doubt I could afford that. I did just find on Home Depot website, a retractable screen door, for home use (see link below). I need to measure mine tonight to see if this would even be an option. Any ideas would be appreciated! Thanks all!
Mike
http://www.homedepot.com/p/ODL-36-in-x- ... /203607600
2011 ECSB Silverado Z71, 3.5 lift, 33's, moto metal 962's ram air hood, tuner
1994 Max II 6x6, 16HP Vtwin Briggs, warn winch, plow, bilge pump
2014 7x12 Slant-V Stealth BlackHawk trailer toyhauler project
MMOLLECK
Re: screen door options for CT?
Postby James06 » Mon Apr 21, 2014 10:33 am
The price seems a little steep. I thought about using the one you see on TV with the magnets. I don't know the name of it, but you can get them at the As Seen On TV stores.
James06
Images: 24
Postby KennethW » Mon Apr 21, 2014 1:18 pm
Maybe try a roller shade with the shade replaced with screen. Sliding down a slot.
Just a thought.
KennethW
Images: 82
Postby kstephenson » Wed Apr 23, 2014 2:32 pm
check my album
I made a sliding screen door
built the frame out of 1 x 4 and bought a full size window screen
mounted on a sliding closet door hardware kit from Lowes
total cost....45 dollars
email me if you have questions [email protected]
Kevin
Kevin
Georgia State Parks Canyon Climbers Club
Hunting - Fishing - Camping- Backwoods
kstephenson
Images: 24
Postby lrrowe » Wed Apr 23, 2014 3:24 pm
When I purchase my CT, if I do not get one with the RV door option with a screen door, I will look at the retractable screen doors like the Phantom one in this video:
http://www.phantomscreens.com/retractab ... ng-screen/
Pricey yes, but there are lower costs versions to search out.
Bob
Bob
lrrowe
Images: 439
Postby Rainier70 » Wed Apr 23, 2014 4:03 pm
The problem with many of the commercial retractable screens is the height. You would have to do some extensive custom cutting to get it to a cargo trailer door height.
For myself I like something simpler. If and when I set up a screen for my door, I plan on using a cafe curtain rod that can be mounted very close to the wall just above the door molding. The rod will be offset to the left so that the screen can hang there in a tie or velcro strap for storage . To use it just pull it across and use either velcro or magnets to hold the right side and bottom close to the frame or molding.
Rainier70
Images: 244
Postby lrrowe » Wed Apr 23, 2014 4:40 pm
Thanks Cindy.
Never gave the height a thought.
Bob
Bob
lrrowe
Images: 439
Postby MMOLLECK » Wed Apr 23, 2014 5:38 pm
Thanks for the responses and input everyone! Kstephenson, your idea is EXACTLY what I dreamt up today! Only thing I added to my thought design, is building a small wall which the screen would slide into, like a pocket door. I only thought that just incase load shifted going down the road
MMOLLECK
Postby PaulS » Wed Apr 23, 2014 7:55 pm
I took a storm door for the house and cut it down with my skill saw and installed it on the inside it has glass and screens
PaulS
PaulS
Postby lrrowe » Thu Apr 24, 2014 7:26 am
This just popped up in my email inbox today. Concept is interesting, but available lengths are probably too long. Unless you could mount it further up the wall from the top or If there was way to shorten it yourself.
On sale now.
Bob
http://www.smarthome.com/6260/Bug-Off-I ... 0-H/p.aspx
Bob
lrrowe
Images: 439
Postby James06 » Thu Apr 24, 2014 8:57 am
lrrowe wrote:This just popped up in my email inbox today. Concept is interesting, but available lengths are probably too long. Unless you could mount it further up the wall from the top or If there was way to shorten it yourself.
On sale now.
Bob
That's the same concept as the ones at the As Seen On TV stores. I will try to get by there sometime this weekend and see if I can find a price, but I think it was cheaper than the smarthome site.
James06
Images: 24
Postby lrrowe » Thu Apr 24, 2014 9:23 am
Online
http://seentv.asseenontv.com/search?w=S ... sug=Screen
1/2 price of Smarthome.
Bed bath and beyond carries many of thee type Products
Bob
Bob
lrrowe
Images: 439
