BC_Explorer wrote:On my trailer, I had the factory install the side window and the sliding window in the side door. You may want to consider having a 2nd roof vent added at the factory and also consider another 6" height increase.
lrrowe wrote:Hi! John,
I took the time to look at the photos in your gallery.
1. I see why you wanted the added height.i probably will never hit roads like that back here in the east. If I could find one on public land, the forest service would block it. So I will use your height choice as a maximum for me to consider.
(JC) The height is about the maximum I would really want to go as towability on the highway is affected -- the flat front trailer adds to the wind dam and resistance, it also adds to the turbulence created by passing or meeting large vehicles like RV's and Semi's. The west still has quite a few old mining and ranching roads and logging roads that are open, but if left to the BLM and the Forest Service, all these roads would be closed!![]()
2. How did you get the shots of the trailer framing while under construction? Do you live close to the factory, or did you talk your builder into doing this for you. I like it. It gives you an excellent view do what is under the skin and plywood.
(JC) I worked with the sales office to put me in touch with the factory manager (they are located about 30 miles from me) and even had plant visits scheduled in the contract, e.g., after the frame was built, before the skin or interior was attached, etc. I contacted the Factory Manager and made arrangement to visit his facility and take photos and keep up with the progress of the trailer. He was actually very helpful and I made several trips out to the plant. I even made a trip before I signed the contract to see what similar trailers were built like and discussed things like electrical, specific layout, and even added the layout drawing to the contract. This relationship helped considerably in getting what I wanted and has helped me locate framing and stud locations for my additions inside (A standard stud-finder works well if in question as to a location of framing)!![]()
3. Like you did for sections of the trailer, I will specify the distance from the front of the trailer and leading edge of the side door. I want to make sure that there is enough room to build a traditional deep cabinet section in the front. I think I will ask for 27 inches. 24 for the cabinet itself, 1 in overhand and 2 inches clearance from the top and door. Of course this depends on how much room is there so as not to interfere with the tires.
(JC) Great planning already and when you get things sketched out, check with your sales office to find out where the trailer will be built and try to arrange a meeting to discuss these changes and anything else, e.g., wiring, lights, additional framing supports, a later AC or heater location, etc. (If the framing is in for any add-ins and skinned over, it is much easier to punch a hole and route the opening than to add the opening and frame it later!) The position of the door was a compromise between the distance from the rear of the cabin to the rear of the door and the distance from the front of the door to the front of the cabin. I needed 74" minimum for a cot behind the door and still wanted room for a small galley cabinet in front of the door -- moving the door forward and making it only 28" (this is actually the same as a narrow door in a house) allowed ample room for both needs.![]()
Bob
