I picked her up finally
Postby Erikh425 » Sat Jun 28, 2014 7:54 am
Some of you may remember a few months back I bought 2 7X16 trailers. One I sold to my father, the other I am going to convert for hauling bikes and general camping and such.
I picked it up a week ago and have insulated it, layed down some garage floor epoxy, and installed some E-Track. I think the only thing left today right now is to load it up with all of my belongings and move to MN.
On a side note, I need to travel with a motorcycle in the bed of my truck and the tail gate down slightly. I would like to keep the trailer jack as far away from my tailgate as possible. My thoughts are to use a slightly lower ball mount, or use a hitch extender. I suppose I could also take the jack off and by a different one. Any ideas?
I will add a link to some pics here shortly.
Thanks for your help getting me this far,
Erik
Erikh425
Re: I picked her up finally
Postby Erikh425 » Sat Jun 28, 2014 8:37 am
I think these are links to my Photobucket pics. Pasting them on my android tablet is a PITA. I'll try to figure it out again later.
https://db.tt/yYmcdcBz
https://db.tt/RTP8fbVc
Erikh425
Postby hankaye » Sat Jun 28, 2014 9:46 am
Erikh425, Howdy;
Depending on what make and model of Motorcycle, you could pull the front
end off then place it sideways in the front of the bed. I did this with an older
H-D Superglide once. Supported the front of the frame on a piece of 12X12.
It's a pain in the butt to shuffle around on your own but it worked for me.
Pick-up was a 1970 F-100 regular sized 8' bed.
hank
hankaye
Postby pchast » Sat Jun 28, 2014 10:59 pm
It would be easier to comment with a pix of the unit attached to the truck
and the tailgate let down. Show the interferance...
What is your expected tongue weight? Would a swinging jack work? Should
you just carry a floor jack in the truck bed with the motorcycle?
:thinking:
Just random thoughts so far.
pchast
Images: 97
Postby Erikh425 » Mon Jun 30, 2014 2:44 pm
I have been away from home for a couple days. I will take some pictures and post them here when I get back. I am pretty sure that I am not going to be removing the front tire from the bike, but it would probably work. I did switch my ball to an insert that dropped the hitch height down a couple inches, so maybe that will give me the space that I need.
Thanks for the advice.
E
Erikh425
Postby AZ_Desert_Rat » Tue Jul 01, 2014 11:04 pm
Erikh425 wrote:Some of you may remember a few months back I bought 2 7X16 trailers. One I sold to my father, the other I am going to convert for hauling bikes and general camping and such.
Erik
Hi Erik,
I sounds like you are off and going ... insulation is in (you will not be sorry _ a tin can without insulation is noisy, wet inside from condensation, and either cold or hot) and I am guessing the garage floor epoxy was to seal the trailer floor ... How did that work; I am still trying to figure out what to use there in my CT Conversion? I just did the same thing and moved from AZ to MN ...where in MN did you move to?
Be careful with the tailgate down ... I have a real short trailer tongue and if my tailgate is down, even a little, it will bump the jack. My jack is welded in and I am stuck with it as it is. 8)
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Postby Erikh425 » Thu Jul 03, 2014 7:53 am
After measuring several times I think that I can get my bike in the bed of my truck and get the tailgate up most of the way. I inverted my ball which dropped the front of the trailer about an inch and a half as well. I can also remove the jack since it is just held on with bolts. I figure the trailer will be harder to steal off of my truck if the jack is locked inside the trailer :)
I looked into a hitch extension, but they reduce the tongue weight capacity by 50%, so that is not going to work. I really don't need the whole thing crashing to the ground.
So far I like the epoxy for the floor. It was fairly easy to put down and seems pretty tough. I did not lay down a primer first, so much of it soaked into the wood. I think that is good for sealing the wood, and it did not leave me with a smooth slippery surface. I also added some of the grit additive for more traction because I have had a slippery garage floor and it was horrible.
I am in the process of moving back to Duluth. I will be leaving here next Saturday to make the trek north.
Erikh425
Postby Erikh425 » Fri Jul 04, 2014 8:23 pm
I believe I solved my problem with the tailgate hitting the jack. While going through my workshop I found my weight distribution hitch. This allows me to move the hitch down an inch and puts it back about 2 inches. I will still probably remove the jack to be safe, but I now have room to breathe I guess. Now if I can find the torsion bars and the chain mounts I suppose I can mount the whole darn thing.
E
Erikh425
Postby AZ_Desert_Rat » Sun Jul 06, 2014 8:44 pm
Hi E,
Thanks for the tips on the gen rack ... I thought you might have made something tricky like roller-sliders (a thoughtful idea), but I do not know if they would hold up to the pounding of some of the roads one might take ... (Hmmm, I-40 can shake the daylights of TV and CT! :shock:
It sounds like the Jack/Tailgate prob is being solved ... good going :applause:
I am not sure I want to raise my propane bottle and battery above the gen or vise versa and will probably continue to drag it out of the TV for a while... :phew: Hmmm, maybe an aft, outside trailer rack would work ... I'll give that some thought :thinking:
My next additions will be the Murphy cots and an awning ... 2 necessities (for me anyway) .. 8)
John (JC)
AZ_Desert_Rat
Images: 55
