Going to CT from Pup.. Insulation Question
Postby mlowry7 » Wed Jul 09, 2014 1:41 pm
Sold my pop up camper and buying a CT. I'm on a limited budget, and will be spending most of said budget on the base trailer. I will be adding upgrades as time and money permits and will be an ongoing build. I live in Texas and will be camping mostly during warm/hot weather. I am wanting to add a window shaker type unit asap. My pup had a roof mounted ac and worked very well at keeping it cool. Here's my question... How much different is a non-insulated pop up than a non-insulated CT. If I wanted to get camping right away, will I be fighting a losing battle at keeping the trailer cool?
mlowry7
Re: Going to CT from Pup.. Insulation Question
Postby cornfused » Wed Jul 09, 2014 3:11 pm
It will cool it fine, but you might get condensation developing inside the walls of the trailer.
cornfused
Postby Glenlivet » Wed Jul 09, 2014 7:49 pm
cornfused wrote:It will cool it fine, but you might get condensation developing inside the walls of the trailer.
It's good to consider, no doubt. Cooler air holds less moisture, still I have a 6x10 with a shaker and uninsulated walls (ceiling is 3" fibreglas) and I haven't experienced any condensation.
Does cool it fine. 5200 BTU drops me from 90 F to 72 F in half an hour.
Glenlivet
Postby OverTheTopCargoTrailer » Thu Jul 10, 2014 8:17 am
mlowry7
As long as you have elec you will be cool :lol: :lol: :lol:
Welcome aboard
OTTCT
Postby bc toys » Thu Jul 10, 2014 8:27 am
It will cool it fine But if you can get the blue board insolation just 1-2 at a time as you can afford to start with the ceiling and then the walls it want be long and you be done but you will want to get it done some time if you need trailer parts there is a great parts store in Arlington called Red Neck Trailer Parts the are very helpful Well good luck with your trailer
bc toys
Images: 42
