hankaye wrote:GuitarPhotog, Howdy;
Not really looking for the strip or rope lights, looking for overhead lights
for the CT I'm fixing to convert. Something like these in Hiflyer's post
http://www.oznium.com/high-intensity-led-floodlight
Can these be wired directly into the 12vdc system??? If so, thenthe only
problem I see may or may not be the temp. of the unit mentioned on the
tech sheet http://www.oznium.com/high-intensity-le ... light/tech
especially if you are mounting it in a ceiling type of environment with close
clearances and insulation ...
hank
absolutsnwbrdr wrote:Oznium seems to be a bit on the expensive side for some of there items. I'll add another vote for http://www.SuperbrightLEDS.com. I order a ton of stuff from http://www.powerwerx.com too.
