Ordered it!
Ordered it!
Postby abqlloyd » Fri Aug 29, 2014 2:30 pm
6x12, V-nose, extra height, RV door, horizontal window, radial tires, vent, electric package, rear stabilizer jacks.
Color matches my truck.
6 to 8 weeks fab time.
Looking forward to getting it going.
abqlloyd
Re: Ordered it!
Postby Doublacola » Fri Aug 29, 2014 3:53 pm
I know you are going to :applause: have fun. Did you get it insulated? Good luck with build.
Doublacola
Re: Ordered it!
Postby lrrowe » Fri Aug 29, 2014 4:04 pm
Congratulation!
I know how you feel. I just ordered mine about 3 weeks ago. Cannot wait.
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby abqlloyd » Fri Aug 29, 2014 5:53 pm
I didn't insulate. I will either buy a spray kit or use the blue closed cell. Possibly a combination of both.
Any tips on the floor? I was thinking 2" blue with spray foam adhesive like Mountain Don. No water tanks to worry about. Maybe cover it with a sacrificial luan.
abqlloyd
Re: Ordered it!
Postby lrrowe » Sat Aug 30, 2014 9:58 pm
abqlloyd wrote:I didn't insulate. I will either buy a spray kit or use the blue closed cell. Possibly a combination of both.
Somewhere is a post by a fellow CT'r who put plywood sleepers (I would guess 3/4 x 6") down on the floor and then added blue foam between the sleepers. It looked tight. I also believe he mentioned the thickness of the top plywood layer he was adding. But I cannot find it. I will continue to search for it as I want to refresh my understanding on what he used as I will use the same process.
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby OverTheTopCargoTrailer » Sat Aug 30, 2014 10:53 pm
Bob
I can't believe that you lost a post ........
I'm sure next your you will no longer be man of all things posted on tntt
:cry: :cry: :cry: :cry: :cry:
Re: Ordered it!
Postby lrrowe » Sat Aug 30, 2014 10:58 pm
Found it! 8)
viewtopic.php?f=42&t=58551
Check out the first link that RWH posts - Toy Hauler Conversion
On the photobucket link, you can see his floor insulation.
At the bottom of the first page of the post, he references using 1/2" plywood over the insulation.
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby lrrowe » Thu Sep 04, 2014 4:15 pm
The factory tells me that my CT will be ready on 9/29. If that date holds true, I will go get it on 10/3. :beer: I will order the windows now and then do my wiring planning so I can buy the wire needed. Can't wait! :ok:
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby abqlloyd » Thu Sep 04, 2014 8:27 pm
I've been ordering parts as well. I found a spray foam kit that looks promising but it might be too late in the year for a proper spray job. It can't be too cold and I don't have an indoor shop anymore.
abqlloyd
Re: Ordered it!
Postby lrrowe » Thu Sep 04, 2014 8:30 pm
abqglloyd,
What type of spray foam are you getting?
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby Arne » Thu Sep 04, 2014 10:00 pm
Do you know how much it will weigh?
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Re: Ordered it!
Postby abqlloyd » Fri Sep 05, 2014 7:57 am
Curb weight is 1500#. Maybe 2500#. My tow vehicle is a full-size truck so weight isn't an issue now.
abqlloyd
Re: Ordered it!
Postby lrrowe » Fri Sep 05, 2014 8:11 am
I am not sure what the weight of mine will be. The manufacturer does not post them. I am guessing at around 1800 lbs for my 6x14 with added 6" height.
Bob
lrrowe
Images: 439
Re: Ordered it!
Postby abqlloyd » Fri Sep 05, 2014 10:03 am
I'm looking at the Foam It 602 kit on amazon.
abqlloyd
Re: Ordered it!
Postby lrrowe » Fri Sep 05, 2014 11:44 am
I would love to use Spray Foam Insulation but I do not think my budget allows me to use this over Blue Foam sheets.
Bob
lrrowe
Images: 439
