Page 1 of 1
Screw sizes
Posted:
Thu Sep 11, 2014 12:37 pm
by Tx River Rat
I have a 2013 lark trailer and need to find the size and type tool to remove screws from the outside skin.
Nothing I have will fit.
Thanks
Ron
Re: Screw sizes
Posted:
Thu Sep 11, 2014 12:57 pm
by kookenotes
Hi - Could be a square drive or a star drive. If you can take a picture the head of it and take it to your local hardware store, they will be able to fix you up with the right bit. Good luck. Bill
Re: Screw sizes
Posted:
Thu Sep 11, 2014 1:14 pm
by MtnDon
It will be a square drive #2 bit. Looks like a star but it is not.
FYI, the hinge and latch hardware looks like a star bit (torx), and is.
Re: Screw sizes
Posted:
Thu Sep 11, 2014 1:52 pm
by walkrdg
I read somewhere (most likely on this forum) the screws on the outside of my Haulmark required a "double-square #2" bit. Like MtnDon said, "It looks like a star, but isn't." I located some for sale on ebay and a couple of other places on line, but I needed to pull only one screw. I tried a standard #2 square. It worked fine.
Re: Screw sizes
Posted:
Thu Sep 11, 2014 8:36 pm
by Mike S
Yep, mine looked like a star but wasn't. When none of my star bits fit, I even called the manufacture to ask what super top secret bit they use. It was a #2 square!
I've called them with a few other silly questions too
Re: Screw sizes
Posted:
Thu Sep 11, 2014 9:08 pm
by OverTheTopCargoTrailer
Big Tex - glad to see ur back , was scared you was working on the Arizona chain gang
If you take the screws out - there goes your Lark lifetime warranty
Cheers OTTCT
Re: Screw sizes
Posted:
Fri Sep 12, 2014 12:41 pm
by Tx River Rat
OTT
Still kicking just not as high
Thanks for the info on the no 2 bit folks.
Ron
